Hi, Has anyone opened up the clutch master cylinder and have some pictures of the piston and seal?
Apart from ordering a expensive piston/spring from Honda, just wanted to check if the seal is attached to the said piston/spring of is a separate item.
i.e. the slave cylinder seal comes with the piston from Honda.
