Goodluckmonkey
TA Friends
Does a 7th gen have a speed limiter?
Had an opportunity to max the car out in a safe environment a little while back, so did so out of curiosity.
Accelerated pretty well to 220kph, then just stopped accelerating, even the transition from level ground to a slight downhill wouldn't change it.
Have I just found the point where the boost tapers and the invrease in aerodynamic drag just suddenly stops it accelerating? Or is there something electronic limiting it? The progress was pretty reasonable for an old diesel till then.
(2.2 CDTI Touring, stage 2 map, lowered 40mm)
