ErikV
Hi,
My aircon is blowing hot air from the start. I finally got around to replace the bits of the aircon that don't work. I started with the compressor (clutch was slipping due to wear). This was relatively straightforward.
I've pinpointed this problem (after checking sensors, pressures and temperatures of the lines) to the next likely suspect, the evaporator core and the main culprit : its expansion valve. Honda has placed this valve inside the firewall, so this will require some work.
Fortunately I found an example for the US version of the Accord, which is 99% correct for the EU spec Accord :
https://www.youtube.com/watch?v=2Ftwfxp0_Qg
This is much less work than completely removing the dashboard! I will be doing this in a few days...
