Jump to content
Clutch only sticking sometimes
  • Please log in to reply
26 replies to this topic
#1 thatcd7
thatcd7
    Newbie
  • Members
  • Pip
  • 11 posts
  • Name:thatcd7
  • Car :1996 honda accord
  • LocationUS
Posted 02 August 2017 - 06:13 PM
Hi guys. This is my first time posting on forums. My cd7 accord is having some clutch sticking problems. It only sticks sometimes. (More often than not) but I can give it a few pumps and it gets some resistance. I know I'm not leaking fluid because my master cyl resivour is staying full. Ive tried changing the master and slave cyl and bleeding it. Any ideas on what it could be?
#2 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,152 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 02 August 2017 - 07:47 PM
How did you bleed ?
Regards,
saj
#3 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,152 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 02 August 2017 - 07:48 PM
Also check for any cracks around clutch pedal
Regards,
saj
#4 thatcd7
thatcd7
    Newbie
  • Members
  • Pip
  • 11 posts
  • Name:thatcd7
  • LocationUS
Posted 02 August 2017 - 08:04 PM
I had my buddy in the car and had him pull up the pedal then push down then I loosened and tightened the bleeder, repeat. But I'll check tonight for cracks. Would I be looking around where the pedal pivots?
Sent from my SAMSUNG-SM-G530A using Tapatalk
#5 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,152 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 02 August 2017 - 08:10 PM
Either use valve or vacuum bleed, gravity bleed does not always work
Edited by honda_saj, 02 August 2017 - 08:12 PM.
Regards,
saj
#6 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,152 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 02 August 2017 - 08:11 PM
Yes look around weld area
Regards,
saj
#7 thatcd7
thatcd7
    Newbie
  • Members
  • Pip
  • 11 posts
  • Name:thatcd7
  • LocationUS
Okay I'll try that. Thanks a lot!
#8 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,152 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 02 August 2017 - 09:41 PM
Not a problem
Regards,
saj
#9 Jan Accord
Jan Accord
    Advanced Member
  • Members
  • PipPipPip
  • 539 posts
  • Name:Jan
  • Car :Honda Accord CN1
  • LocationSlovenia
Posted 02 August 2017 - 09:52 PM
If you are not loosing fluid you can still get air in the system trough the clutch cylinder connected to the pedal.
This is a common fault on WV cars
#10 thatcd7
thatcd7
    Newbie
  • Members
  • Pip
  • 11 posts
  • Name:thatcd7
  • LocationUS
Posted 02 August 2017 - 10:36 PM
Gotcha. I'll take a look at that as well.
#11 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
  • Car :2005 Tourer i-CTDi
Posted 03 August 2017 - 04:23 PM
Not sure about this model, but some Hondas present significant problems in completely removing all trapped air from the slave cylinder...
I've heard of some Civic owners having to unbolt and elevate the slave cylinder during bleeding and also on Accords for the slave cylinder to require the rod to be forced in during bleeding to compress the cylinder volume to eliminate air pockets.
  • freddofrog likes this
#12 thatcd7
thatcd7
    Newbie
  • Members
  • Pip
  • 11 posts
  • Name:thatcd7
  • LocationUS
Posted 03 August 2017 - 04:35 PM
Thanks for the advice. I'm going to be working on it tonight so I'll give that a try.
  • honda_saj likes this
#13 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
Posted 03 August 2017 - 06:03 PM
Good luck!
Please come back with good news...
#14 thatcd7
thatcd7
    Newbie
  • Members
  • Pip
  • 11 posts
  • Name:thatcd7
  • LocationUS
Posted 04 August 2017 - 01:04 AM
Okay, so, ive checked near the pedal for cracks. Nothing. I power bled the system and it worked when I took it for a spin around the block and then right before I got to the driveway it went to the floor. Maybe its a faulty slave cyl? Or master cyl? Other than that I'm out of ideas.
#15 Jan Accord
Jan Accord
    Advanced Member
  • Members
  • PipPipPip
  • 539 posts
  • Name:Jan
  • LocationSlovenia
Posted 05 August 2017 - 07:10 AM
There are only 3 options
1. Faulty master cylinder
2. Faulty slave cylinder
3. Air in the system
If you ask me i would point the finger on the master cylinder behind the pedal
  • freddofrog and honda_saj like this
#16 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,152 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 05 August 2017 - 05:25 PM
Yes I agree would be inclined to check cmc ensure their is no split on reservoir hose to where air can be introduced otherwise look at replacing cmc.
Regards,
saj
#17 thatcd7
thatcd7
    Newbie
  • Members
  • Pip
  • 11 posts
  • Name:thatcd7
  • LocationUS
Posted 05 August 2017 - 06:21 PM
Alright. That'll be the next thing I replace. Thanks for all the advice.
#18 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,152 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 06 August 2017 - 02:12 PM
No problem keep us advised
Regards,
saj
#19 thatcd7
thatcd7
    Newbie
  • Members
  • Pip
  • 11 posts
  • Name:thatcd7
  • LocationUS
Posted 12 August 2017 - 02:20 PM
Sorry for not keeping you guys updated. Ive been super busy and with two jobs I don't get a lot of time to get stuff done. I replaced the slave cylinder first and got it bled because it was a lot easier. That didn't work so the other night I replaced the master cylinder. Haven't got it bled yet due to limited time. But should have it done within the next couple of days. I'm really hoping thats what's going on. Thanks to all for all of the advice. I'll post again when I get this master cylinder bled.
  • Jan Accord likes this
#20 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,152 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 12 August 2017 - 08:51 PM
Cool how are you bleeding using vacuum pump or one way valve gravity bleed does not work all ways especially on clutches
Regards,
saj
