Jump to content
Clutch only sticking sometimes
  • Please log in to reply
26 replies to this topic
#21 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,151 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 12 August 2017 - 08:53 PM
Also after replacing clutch master cylinder, bleed from slave then once all air removed push slave piston fully in and bleed again that way you will bleed slave and master properly a key technique that gets overlooked and then people say they have spongy clutches
Regards,
saj
#22 thatcd7
thatcd7
    Newbie
  • Members
  • Pip
  • 11 posts
  • Name:thatcd7
  • Car :1996 honda accord
  • LocationUS
Posted 12 August 2017 - 11:30 PM
Awesome. I'm glad you said something before I got to it. Thanks a bunch. I'll definitely do that.
Sent from my SAMSUNG-SM-G530A using Tapatalk
  • honda_saj likes this
#23 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,151 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 13 August 2017 - 02:50 PM
No problem keep us posted
Regards,
saj
#24 Mr vtec
Mr vtec
  • Members
  • PipPip
  • 18 posts
  • Name:Brian
  • Car :Vtec sport 6 gen
  • LocationNorth east
Posted 14 August 2017 - 02:49 PM
When I did my 6 gen accord clutch replacement the slave had seized in the retracted position hence why my pedal wasn't returning back on it's own, after flushing out the contaminated fluid in the system (was very dirty ) the slave started to work again and the pedal was fine after that.
Get somebody to make sure the pivot arm on the box moves freely when the clutch is depressed and released if no movement or very little it's the slave that's the problem. Pita to bleed the slave too as the bleed nipple is right up against the engine mount bracket.Undo the 2 bolts for the slave and lift it up a little and that gives you clearance to bleed easier.
#25 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,151 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 14 August 2017 - 04:15 PM
Yes good point I always release and bleed then bolt down much easier to do
Regards,
saj
#26 thatcd7
thatcd7
    Newbie
  • Members
  • Pip
  • 11 posts
  • Name:thatcd7
  • LocationUS
Posted 15 September 2017 - 05:25 PM
Sorry about the delay on an update. I got the car going. It ended up being the master cyl bypassing. Got it changed and the clutch works like a beauty. Thanks for all the help from everyone!
  • honda_saj and Bounder like this
#27 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,151 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 17 September 2017 - 03:55 PM
Great [emoji106] result
Regards,
saj
