Jump to content
Accord iDTEC "misfires" and cuts off.
  • Please log in to reply
36 replies to this topic
#1 Acco_idtec
Acco_idtec
  • Members
  • PipPip
  • 16 posts
  • Name:Simo Sällinen
  • Car :Accord tourer iDTEC
  • LocationFinland
Posted 10 August 2017 - 03:16 PM
Hi guys.
This is my first post here, though I've been browsing here for a while when troubleshooting things. Sorry for my english, I'm a finnish dude so its defo not fluent! 😀
So, I'm having some nasty problems with '09 tourer 2.2 iDtec. The car has 233 000km on it's clock.
Symptoms:
- The fault is continuos and has been present for about a week now.
- When idling, the engine "misfires" randomly at 1-20 sec intervals.
- When driving, the car stumbles at same intervals.
- When reaching normal coolant temperature, car tends to cut out. There has been couple of occasions, when I had to wait for approx 30min after the cutout to get the car started.
- Otherwise the engine starts easily and there's no excess smoke to be seen.
- NO check engine etc. lights flashing.
Notes:
- No fuel leaks.
- NO DTC:s to be found. I've read the log with Auto-Com & launch pro -testers. (No access to HDS yet).
- The car is re-mapped with dpf & egr elimination.
- The fuel filter has been changed ~2000km ago. Oem part.
- We were able to do a rail pressure test with launch pro. Result 1800bar.
- When idling, the rail pressure is around 260-280bar. The MAF-voltage is ~1,8V.
- Dunno the right term in english, but theres a slight difference in the injectors "correction amount" Cyl. 2 is -1,7 while the other ones are at +0,6.
- Most interesting thing is, that the crankshaft pulse sensor gives the values of either "63220" or "0". Revving the engine doesn't affect the values. Still, the RPM-signal is correct at the tester.
If theres any hints or ideas where to begin, I'd be glad to hear those! Taking the car to the dealer service is the last call, as its gonna cost some serious money..
#2 Jan Accord
Jan Accord
    Advanced Member
  • Members
  • PipPipPip
  • 539 posts
  • Name:Jan
  • Car :Honda Accord CN1
  • LocationSlovenia
Posted 10 August 2017 - 03:40 PM
Hi and welcome
That's for sure a fuel cut off for some reason.
The most common check up you already did...good work
All the parameters you mentioned are OK so the fault is not where you are searching, even the injector correction per cycle.
If i would be you i will take the injectors out and send them to an good company for check up, and check the cylinder compression.
  • freddofrog likes this
#3 Acco_idtec
Acco_idtec
  • Members
  • PipPip
  • 16 posts
  • LocationFinland
Posted 10 August 2017 - 04:46 PM
Hi and welcome
Thank you for your quick reply.
I also guess that it's a fuel cut for some mysterious reason. When the car "dies" properly, first it cranks after the cutoff, but doesn't run for more than just a second. A bit later, it starts and idles but doesn't rev. So It takes totally about 30min for the car again to work as well as it does in this condition.
Does the ECU cut off the fuel supply, if, for example just 1 injector is faulty?
I was also wondering, could a dodgy inertia switch cause these symptoms as there is no check engine-lights or fault codes to be seen?
That injector test totally should be done, I just don't have a decent diesel specialist nearby, so its gonna take some time to find a proper garage who could test em.
Can I get a clue about the injectors condition for example, by making some resistance measurements?
#4 Jan Accord
Jan Accord
    Advanced Member
  • Members
  • PipPipPip
  • 539 posts
  • Name:Jan
  • LocationSlovenia
Posted 10 August 2017 - 07:00 PM
If your ECU does not recognise any fault than somewhere must be a mechanical fault... where the "check" sensor is not mounted as already mentioned injectors.
The resistance measured on the injector will show you only the state of the electromagnetic valve which opens and closes the injector when needed.
Search for some decent BOSCH service around there with good reputation of the company.
If you don't have any around there take them out your own and sent them.
Belive me...it's better that the injector service takes few days more with postage included and costs a bit more, than you take the injector to some "specialist"...
If the injectors are not prepared as they should, the can cause problems bigger than you expect, and you will still have in mind that " the injectors are rebuilded" and point the problem solving in some other way
#5 TourerFan
TourerFan
  • Members
  • PipPip
  • 54 posts
  • Name:Pete
  • Car :idtec tourer manual
  • LocationWakefield
Posted 10 August 2017 - 07:16 PM
Hi Simo,
              if you think it is injector trouble you could try this :-
Open the diesel filter top and remove the diesel filter.
Remove the fuel from the chamber and refit the filter.
Fill the chamber body with a good quality diesel injector cleaner.
Refit the filter top and and run the engine for about 30 seconds.
Switch off and leave over night for the diesel injector cleaner the do its job.
Next day give the car a good run out and use the revs to the full once or twice.
This method has been known to improve/clean up diesel injectors.
Cheers, Pete.
P.S. let us know the outcome.
#6 Jan Accord
Jan Accord
    Advanced Member
  • Members
  • PipPipPip
  • 539 posts
  • Name:Jan
  • LocationSlovenia
Posted 10 August 2017 - 07:19 PM
Hi Simo,
Cheers, Pete.
This could be also a solution...but you need to be careful what you put in.
Strongly avoid any aditive with alcohol or any other aggresive solvent.
It must be based on parafin oil like Antigrippante 25.
  • honda_saj likes this
#7 Acco_idtec
Acco_idtec
  • Members
  • PipPip
  • 16 posts
  • LocationFinland
Posted 11 August 2017 - 03:15 AM
Thx for these additions, I'll try to get my hands on that stuff and have a go on that treatment first!
#8 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
  • Car :2005 Tourer i-CTDi
Posted 11 August 2017 - 09:15 AM
...Dunno the right term in english, but theres a slight difference in the injectors "correction amount" Cyl. 2 is -1,7 while the other ones are at +0,6.
That's normal... the ECU will always assess one 'mid-range' injector to be the baseline then reference the other three injectors to it. Logically then two injectors will be either plus or minus in relation, while the fourth will be the opposite. Your results are completely normal and so do not indicate an injector problem. I'm not dismissing the suggestion, but I would therefore be wary of running practically neat cleaner through the injectors (or particularly the pump) in case the lack of lubrication causes excess wear, at least until I had ruled out other things.
If this was an i-CTDi diesel (with the previous 3rd generation Bosch injection system) then I would focus on either the rail over-pressure valve intermittently releasing rail pressure (by channelling the return into a container and blocking the loose pipe) or the M-Prop (pressure regulator solenoid) on the fuel pump being a bit sticky. I've suffered both these faults!
You appear top have access to advanced diagnostic equipment, so why not log engine parameters whilst driving around?
#9 Acco_idtec
Acco_idtec
  • Members
  • PipPip
  • 16 posts
  • LocationFinland
Posted 11 August 2017 - 02:40 PM
Thank you very much for sharing knowledge about the injector correction amounts! That's certainly new info for me.
I found a topic about the relief valve diagnosis on a i-ctdi. This: http://www.civinfo.c...#/topics/111264
Does this apply to iDTEC also, or are there major differences in that area? Shame that the pictures in this topic do not show anymore.
About the diagnostics, I do have the Autocom software, but at the moment its in a laptop with a s****ty battery, so I can only use it stationary.
The LaunchPro that I mentioned is owned by a guy I know, so I don't have everyday access to it.
We did a drive with LaunchPro connected, and we monitored The actual fuel rail pressure and it's target pressure. They seemed to go pretty much together, even when the engine was stumbling.
#10 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,105 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 11 August 2017 - 03:08 PM
Jon any ideas ?
Regards,
saj
#11 F6HAD
F6HAD
    Affiliate / Co-Founder
  • Administrators
  • 12,639 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 11 August 2017 - 05:27 PM
I'm sorry the most obvious culprit here is the remap.
It's not possible for such a major malfunction to take place where you engine is actually cutting out and no DTC is being logged. Your tuner has most likely deleted either a bank or an entire table of DTC's because they didn't know how to remove a DPF regen cycle or switch off an egr.
I see this stuff day in day out now.
Was this happening before it went to them?
Have your ecu flashed back to stock and then test it.
Posted Image
#12 Acco_idtec
Acco_idtec
  • Members
  • PipPip
  • 16 posts
  • LocationFinland
Posted 11 August 2017 - 05:51 PM
Ok, that's also one of the scenarios I was afraid of. The remap was done during the previous owner, so I don't know if there was symptoms like this before the remap.
But I do know the company who made the remap, so I have to give them a call next monday.
About a year ago, I had a couple of cutoffs after a full throttle acceleration, but back then I was able to find a MAF-related DTC with Autocom and everything fixed by cleaning the air sensor.
But if it's possible to remove just a bank of DTC's (like EGR-related) then that might be the case.
Which makes me wonder, could I track a faulty EGR-valve by monitoring the target & the actual intake air amounts going into the engine?
#13 TourerFan
TourerFan
  • Members
  • PipPip
  • 54 posts
  • Name:Pete
  • LocationWakefield
Posted 11 August 2017 - 07:04 PM
Hi Simo,
             Below is a list of  MAF readings taken using "Torque" app. with an android phone. This was taken with the car stationary and from it you may be able to check for a faulty  EGR valve.
Engine temperature 80 degree C
                                Revs                                         Grams/stroke
                              820 (idle)                                               7.3
                            1000                                                        9.7
                            1500                                                      15.1
                            2000                                                      18.5
                            2500                                                      32.4
                            3000                                                      58.00
Hope this helps,  Pete
  • Jon_G and Acco_idtec like this
#14 Jan Accord
Jan Accord
    Advanced Member
  • Members
  • PipPipPip
  • 539 posts
  • Name:Jan
  • LocationSlovenia
Posted 12 August 2017 - 03:22 AM
Is that really possible?? To delete the DTC's?
#15 F6HAD
F6HAD
  • Administrators
  • 12,639 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 12 August 2017 - 09:49 AM
Absolutely yes, and more and more so called tuners are doing it because it's very easy to do, and it's far easier than taking the time to understand individual mapping structures to correctly close egr maps and DPF cycles. They just delete errors permanently and hand the car back with a horror of problems brewing in the background.
Even with some very basic knowledge any novice can download a flash and use some online software to delete a DTC table. It's an extremely dangerous thing to do.
I had an Accord just this week from a forum member here who had lost hope in it. It was cutting out and throwing bags of smoke and losing power but no garage or the RAC could diagnose it because their machines were showing no DTC codes.
I had solve it by rebuilding the software and reinstating all the error codes. Turns out his egr was sticking open so it was solved with our egr off solution.
  • honda_saj and Acco_idtec like this
Posted Image
#16 Jan Accord
Jan Accord
    Advanced Member
  • Members
  • PipPipPip
  • 539 posts
  • Name:Jan
  • LocationSlovenia
Posted 12 August 2017 - 11:13 AM
Omg. You never know what you buy and then even when you pay for something when upgrading the car.
The only hope are you guys, specialized in what you do.
#17 Acco_idtec
Acco_idtec
  • Members
  • PipPip
  • 16 posts
  • LocationFinland
Posted 13 August 2017 - 10:19 AM
Ran the Autocom test again, stationary as always. This is what I got:
Maf-values
Idle (720rpm) 12,3g/s
1500 rpm 29.5g/s
2000 rpm 43g/s
2500 rpm 53,4g/s
3000 rpm 62,5g/s
These are indeed higher than the reference values TourerFan shared.
Air mass/stroke @3000rpm
Target 540mg
Actual 630mg
Egr position devation between -2% & 0%
Egr valve status continuously OPEN
EGR cooler bypass 100% when idling, when revving 0%
Tomorrow I'm gonna give a call to the tuner company, and ask did they blank the egr at all or did they do the removal only software-wise.
Also going to ask about deleting the DTC-banks. Just hoping they'd give me a honest answer.
Edited by Acco_idtec, 13 August 2017 - 12:21 PM.
#18 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,105 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 13 August 2017 - 02:51 PM
Hope you get sorted soon
Regards,
saj
#19 F6HAD
F6HAD
  • Administrators
  • 12,639 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 13 August 2017 - 03:56 PM
Instead of looking for honest answers just ask them to reflash it to the original factory setting file and then drive it to see what DTC codes appear. You should get p2002 for the DPF but anything additional will be what's causing your issue.
Posted Image
#20 Acco_idtec
Acco_idtec
  • Members
  • PipPip
  • 16 posts
  • LocationFinland
Posted 15 August 2017 - 03:05 AM
So, I gave a call to the tuner company. They would charge me a good few hundred € for flashing it stock, so I thought I'd try everything else before that manouver.
They said, yes, the EGR-valve position is locked only software-wise and the EGR-related DTC library is removed. So I assembled a blanking plate between the exhaust manifold & EGR-pipe. It made no difference..
Still wondering why the actual airmass/stroke is a lot higher than the target.
Also had a drive with maf-sensor disconnected. The car went to limp-mode as it should. But on limp mode there was no hesitation or stumbling to be noticed. Trying to get my hands on a maf-sensor which for sure works properly and have a go with that.
Otherwise I'm running out of ideas, so better start saving money for some re-flash/visiting the dealer garage..
