Alignemt settings CL9 with Euro R Suspension
Rinesh
Netherlands
Accord 2.4 Executive
Can someone help me with the proper alignment settings for a Euro R (CL7) Accord?
Since my car is fitted with the honda sport suspension (A-spec) 08W60-SEA-600 and according to my search, this is the Euro R suspension, I want to get those alignment setting.
Unfortunately they do not have the settings here (hunter machine)
I want to get a proper alignment so i would appreciate it if someone can help me with the settings.
Same as cl9..your better off getting rear camber adjusters and ask tom at tgm motorsport for his fast road setup
i use
Front neg 2 degrees camber
Rear neg 1.5 camber
1mm toe out front
1mm toe in rear.
With progress rear anti roll bar
Its amazing how different settings can change the cars handling
@ukcl9: Do you think CL9 and EuroR settings are the same? Problem I am having is that at center the steering feels little dead and at higher speeds, i feel that steering is al little to light. It should have been a bit heavier...
Since the car recently got a full inspection, they could not find any worn bushes or any suspension part.
So they said that it could be caused by wrong alignment....
