Accord-EX
Have many of you guys changed the lower control arms in your 7th Gen accords?
My 2.2 icdti is approaching 160k miles and I've noticed the lower compliance bush is torn and will need replaced so I was going to replace both control arms which will come with bushes pre fitted. There seems to be a number of different manufactures at different prices - which are recommended?? I dont think I'll want to fork out Honda prices but at the same time I dont want cheap Chinese versions either.
I've also got 2 ball joints which I'd like to fit but this will require a bench to press them in - do you think its ok to not replace or is this a good time to just go get these done as well
