Jump to content
Intermittent airbag light
  • Please log in to reply
20 replies to this topic
#1 Stevearcade
Stevearcade
    TA Friend
  • Super Moderators
  • 6,800 posts
  • Name:Steve
  • Car :2003 Accord CM2
  • LocationEastbourne
Posted 20 August 2017 - 03:42 PM
As per title. In the last week or so my airbag light's been coming on. It seems to be pretty random, i.e. not triggered by particular circumstances (that I've noticed). If I turn the car off and on again, the airbag light goes away for a while.
I'm guess either a faulty sensor or some loose wiring. I don't remember ever reading about this on anyone else's car. Does anyone have any experience of this and can recommend a good course of action. I imagine there are a lot of impact and roll sensors throughout the car which could make troubleshooting the issue tricky, especially as it seems to come on sporadically.
Thanks in advance for any help.  :)
My CM2 - Cold Air Intake with K&N Filter, Custom 2.5" Stainless Steel Exhaust, Reflashed ECU, Custom Made 8J Steelies from Extreme Offset, BC Racing Coilovers, Short Shifter, Type-R Gear Knob, XCarLink iPod Interface, Interior & Exterior LED Bulb Conversion, Wind Deflectors, Yellow Fog Lamps, JDM size plates, Type S Grill (with blacked out chrome), Front & Rear Type S Skirts.
#2 Stevearcade
Stevearcade
    TA Friend
  • Super Moderators
  • 6,800 posts
  • Name:Steve
Posted 20 August 2017 - 05:10 PM
Ok, I've looking into it a bit more. Common causes are loose/faulty connections in the steering wheel itself or the system tripping as it gets odd signals from the seat belt buckle switch sensor that is intrinsically linked to the airbag circuit for pretty obvious safety reasons.
I've watched a couple of videos and from that, I've gone and undone and cleaned the connector for the airbag first of all. I'm going to keep an eye on the seatbelt light and if the problem persists or if I notice the seatbelt light go on, I'm going to clean the seatbelt buckle switch sensor (which looks like a very similar design to the ABS switch on the brake pedal, which I've fixed before. It's just a thin metal strip that is vulnerable to getting dirty and not contacting cleanly.
#3 Stevearcade
Stevearcade
    TA Friend
  • Super Moderators
  • 6,800 posts
  • Name:Steve
Posted 20 August 2017 - 05:11 PM
For reference, videos I watched were:
  • freddofrog likes this
#4 Stevearcade
Stevearcade
    TA Friend
  • Super Moderators
  • 6,800 posts
  • Name:Steve
and...
#5 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
  • Car :2005 Tourer i-CTDi
Posted 20 August 2017 - 06:59 PM
Have you responded to Honda airbag recall?
#6 freddofrog
freddofrog
    won 16.4k on Euro lottery :)
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
  • LocationOff abroad
Posted 20 August 2017 - 07:39 PM
I'm not sure that the airbags themselves have any link to the airbag light, don't they just receive  a "fire" input from the SRS trigger system ?
#7 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
Posted 20 August 2017 - 07:56 PM
It wouldn't be very complicated for the system to also monitor the continuity of the airbag circuit. Plenty of other sensors and actuators have their continuity monitored.
#8 freddofrog
freddofrog
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
Posted 20 August 2017 - 08:40 PM
so I've had a look at the circuit diagram and sadly ......
it's not obvious LOL
Edited by freddofrog, 20 August 2017 - 09:45 PM.
#9 freddofrog
freddofrog
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
Posted 20 August 2017 - 09:47 PM
The SRS also fires seat-belt tensioners, and I suppose that if the system thinks that a seat belt isn't plugged in, it won't fire the seat-belt temsioner for that seat. (you wouldn't want a loose buckle smashing you in the side of your head as your head is hitting the airbag).
Without unplugging an airbag on a working system, it's not clear whether the light will come on or not.
#10 Stevearcade
Stevearcade
    TA Friend
  • Super Moderators
  • 6,800 posts
  • Name:Steve
Posted 20 August 2017 - 11:18 PM
I unplugged the airbag and started the car. The light was on. Turned the car off, plugged the airbag in and the light was off. Like I said, I've cleaned the contacts in the airbag connector and will monitor the situation. If it persists I'll tackle the next two commonly documented issues of the seat belt buckle switch and then then the (whatever it's called) thing that sits at the back of the steering wheel and communicates with the SRS system. Whatever's causing it, I expect it's dirty contacts on a switch/connector somewhere.
#11 freddofrog
freddofrog
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
Posted 21 August 2017 - 05:30 AM
FYI I've also found this by putting "SRS description" in the search in the ESM.
The side airbag system also includes an occupant position detection system (OPDS). This system consists of sensors and a OPDS unit in the front passenger's seat-back. The OPDS unit sends occupant height and position data to the SRS unit. If the OPDS unit determines that the front passenger is of small stature (for example, a child) and the front passenger is leaning into the side airbag deployment path, the SRS unit will automatically disable the passenger's side airbag. The SRS unit will also disable the airbag when the OPDS detects certain objects on the seat. When the side airbag is disabled, the side airbag cutoff indicator on the instrument panel alerts the driver that the passenger's side airbag will not deploy in a side impact. When the object is removed, or the passenger sits upright, the side airbag cutoff indicator will go off after a few seconds, alerting the driver that the passenger's side airbag will deploy in a side impact
#12 Stevearcade
Stevearcade
    TA Friend
  • Super Moderators
  • 6,800 posts
  • Name:Steve
Posted 21 August 2017 - 10:19 AM
Is this for our cars? What does the side airbag light look like? I don't think I've ever seen it.
#13 freddofrog
freddofrog
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
Posted 21 August 2017 - 10:59 AM
yep 2004 CM2 in the 7th gen ESM, I'm not sure what they mean by "side airbag cutoff indicator" as there's only one indicator light shown in the SRS system circuit diagram
#14 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
Posted 21 August 2017 - 11:47 AM
Can you get it looked at using HDS Steve? If the SRS system can be 'interrogated' in a similar way to the powertrain and ABS/VSA systems, then a stored error code would presumably point to the problem causing the warning light to come on.
#15 Stevearcade
Stevearcade
    TA Friend
  • Super Moderators
  • 6,800 posts
  • Name:Steve
Posted 21 August 2017 - 12:49 PM
That's good to know. Cheers fellas.
#16 freddofrog
freddofrog
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
IIRC there is an SRS menu on the HDS
yep, found the pic that I posted eleswhere
Edited by freddofrog, 21 August 2017 - 12:57 PM.
  • Jon_G likes this
#17 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
Posted 21 August 2017 - 01:41 PM
There you go then...
#18 Stevearcade
Stevearcade
    TA Friend
  • Super Moderators
  • 6,800 posts
  • Name:Steve
Posted 21 August 2017 - 03:04 PM
Nice one. I'll keep an eye on it. I cleaned the contacts on the airbag connector yesterday and the problem's not come back yet. If it does I'll look into an HDS as I should probably have one of my own, given the cars age  :rolleyes:
#19 Timberfake
Timberfake
    Advanced Member
  • Members
  • PipPipPip
  • 149 posts
  • Name:Justin
  • Car :Accord v-tec s
  • Locationnewport
Posted 12 March 2018 - 10:03 AM
Did the light come back on? My light comes on I've had it turned of by garage twice it's stayed of for 1000 miles and then comes back on...
Sent from my G8341 using Tapatalk
#20 Stevearcade
Stevearcade
    TA Friend
  • Super Moderators
  • 6,800 posts
  • Name:Steve
Posted 12 March 2018 - 12:33 PM
Not come back since. I'm certain it's a dirty contact issue. I work with electronics a lot and am used to cleaning switch contacts. My gut feeling on this is definitely the contact in the steering wheel boss.
