Door locks and barrel swap?
Comedywizard
Vale of Glamorgan, South Wales
Accord Coupe
Car = 1998 Coupe 2.0 .
Can anyone confirm if this model has a chipped key? I don't think it does as it looks fairly standard to me?
Reason for asking is that my car only has one key which opens the passenger door, valet boot lock and ignition, but it does not work in the drivers door or boot. So I presume driver door and boot locks have been changed in the past.
Obviously I would like to have one key that works in all locks and so hoping to get a second hand set with matching keys to change over. If it is standard without chip then obviously will be easier and cheaper to change over the barrels.
Again would barrels and keys from a saloon work or even from civic or similar era Honda, as more likely to get hold of a set
im not sure but if your key opens and there is chip inside then you will know i dont believe that year has chip could be wrong though easiet way would be to contact a local auto locksmith
see here
http://www.locksmiths.co.uk/
