Jump to content
Clutch bite point.
  • Please log in to reply
15 replies to this topic
#1 MyfirstVtech
MyfirstVtech
    Advanced Member
  • Members
  • PipPipPip
  • 139 posts
  • Name:steven green
  • Car :honda accord
  • LocationCheshire
Posted 07 September 2017 - 09:19 AM
Ok so this has probably been covered somewhere but my clutch bite point is about 2/3 way up the pedal and I wanted to lower it abit so it's bites further down.
Did I read right that on the clutch pedal you remove a locking pin and wind the rod?
Which way do I wind and what should I be looking for?
#2 accord_n22
accord_n22
    Advanced Member
  • Members
  • PipPipPip
  • 667 posts
  • Name:Alex
  • Car :Honda Accord I-CTDI
  • LocationHertfordshire
Posted 07 September 2017 - 09:03 PM
What model of accord have you got - year, engine size, petrol or diesel?
Always thought Honda clutches were self adjusting.
#3 MyfirstVtech
MyfirstVtech
    Advanced Member
  • Members
  • PipPipPip
  • 139 posts
  • Name:steven green
  • Car :honda accord
  • LocationCheshire
Posted 07 September 2017 - 09:39 PM
2001 1.8 petrol. 🙂
#4 freddofrog
freddofrog
    won 16.4k on Euro lottery :)
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
  • LocationOff abroad
Posted 07 September 2017 - 11:55 PM
I'm not sure if there is any adjustment, but yes if there is, it will most likely be achieved on the rod that goes from the pedal into the master cylinder. You'd need to extend it outwards a small amount.
Note that on hydraulic clutches on 6th/7th/8th gen manual-gear petrol Accords, the biting point will stay the same while the clutch wears, "auto adjust" taking place in the slave cylinder. But eventually the "auto adjust" can go no further, so if the biting point starts to get too high, it indicates the clutch thickness is getting near to the limit.
#5 freddofrog
freddofrog
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
Posted 08 September 2017 - 12:45 AM
 ooops, cat woke me and said "shorten it" (move rod inwards) LOL .... but you might find that that introduces some "slack" in the pedal
#6 MyfirstVtech
MyfirstVtech
    Advanced Member
  • Members
  • PipPipPip
  • 139 posts
  • Name:steven green
  • Car :honda accord
  • LocationCheshire
Posted 08 September 2017 - 12:53 AM
Hahaha ok, I've studied the pictures and instructions and so with both lock nuts loose I turn the push rod clock wise to lower the bite point?
#7 freddofrog
freddofrog
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
Posted 08 September 2017 - 07:32 AM
I'm only going on the way the clutches on the 7th gen petrol Accords work and as far as I can make out the 6th gen is same, so if it is the same and if it does screw inwards, then yes.  But in effect, all that you're doing is moving the pedal in a bit, relative to the movement of the piston in the master cylinder that affects the movement of the clutch pressure plate.
#8 MyfirstVtech
MyfirstVtech
    Advanced Member
  • Members
  • PipPipPip
  • 139 posts
  • Name:steven green
  • Car :honda accord
  • LocationCheshire
Posted 08 September 2017 - 07:43 AM
Ah so all it does is move the pedal height and not change the point when pushing the pedal where the clutch bites??
#9 freddofrog
freddofrog
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
Posted 08 September 2017 - 08:14 AM
That's correct. On a cable-operated clutch, the biting point can be adjusted, a bit like adjusting the point at which the brakes on a push-bike start to work, relative to the lever position. But a hydraulic clutch self-adjusts, in the same way that the hydraulic brakes on the car also self-adjust.
On the brakes, as the friction material wears, the piston moves out from the caliper, but the pedal stays in the same position. On a hydraulic clutch, as the friction material wears, the fingers on the pressure plate move further outwards, so the piston in the hydraulic slave cylinder moves inwards, but the overall effect on the pedal is same as on brakes i.e. no effect on when the piston(s) in the slave cylinder(s) start to move, relative to pedal position.
#10 MyfirstVtech
MyfirstVtech
    Advanced Member
  • Members
  • PipPipPip
  • 139 posts
  • Name:steven green
  • Car :honda accord
  • LocationCheshire
Posted 11 September 2017 - 03:53 PM
Freddo you are just awesome for useful and fully explained info and from what you have told me its best just to leave it as is.
Any idea what the average mileage is of a 1.8 2001 original clutch life?
My old Celica gen 6 was anything from 115-120k.
#11 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
  • Car :2005 Tourer i-CTDi
Posted 11 September 2017 - 05:25 PM
Freddo you are just awesome...
In the same way as wasps?
  • honda_saj likes this
#12 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
Posted 11 September 2017 - 05:26 PM
...My old Celica gen 6 was anything from 115-120k.
That's very precise. Normally it would depend upon how it's been driven and how much was motorways journeys.
#13 MyfirstVtech
MyfirstVtech
    Advanced Member
  • Members
  • PipPipPip
  • 139 posts
  • Name:steven green
  • Car :honda accord
  • LocationCheshire
Posted 11 September 2017 - 06:05 PM
Wasps?
Ah hmm yes I should have said that on average the club guys it would close to either of those figures on average mileage.
#14 freddofrog
freddofrog
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
Posted 11 September 2017 - 07:28 PM
Wasps?
He's been on the red diesel again  :lol:
Edited by freddofrog, 11 September 2017 - 09:29 PM.
#15 MyfirstVtech
MyfirstVtech
    Advanced Member
  • Members
  • PipPipPip
  • 139 posts
  • Name:steven green
  • Car :honda accord
  • LocationCheshire
Posted 11 September 2017 - 08:53 PM
Hahahahahahaaha gooooood s***
#16 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,015 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 13 September 2017 - 11:00 AM
  • freddofrog likes this
Regards,
saj
