Jump to content
ABS VSA module detached
  • Please log in to reply
5 replies to this topic
#1 hale-pope
hale-pope
    Advanced Member
  • Members
  • PipPipPip
  • 135 posts
  • Name:Benedict OHalloran
  • Car :10 i-dtec tourer ex
  • LocationUnited Kingdom
Posted 13 September 2017 - 04:35 PM
I wonder if anyone can help.  After a slightly humpy road and small bash on the underside of the front bumper a mass crash of the electrical system happened where all the ABD VSA power steering and big ! lights came on and also my brake lights!  A clear of the codes brought up that the 'module cannot be read as has become detached'.  Has anyone had this before at all?  The concerning bit is the brake lights being on even when the car is off and locked so i may get a flat battery!
#2 Cliffordski
Cliffordski
    And still...
  • TA Friends
  • PipPipPip
  • 1,411 posts
  • Name:Cliff
  • Car :06 Tourer 2.4 EX man
  • LocationCounty Durham
Posted 13 September 2017 - 04:51 PM
A bulb can flatten a battery overnight so might be worth disconnecting the negative terminal until you get sorted out.
  • freddofrog likes this
#3 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 854 posts
  • Name:Stephen
  • Car :Accord 7 Estate 2005
  • LocationKT8 Postcode
Posted 13 September 2017 - 05:27 PM
You need to get a light under there to check where the problem is.
I had a cut in the loom on a Nissan Vanette, road damage just behind the front wheel on the drivers side, which looked suspiciously like the previous owner had run over a high kerb.
Edited by Channel Hopper, 13 September 2017 - 05:28 PM.
#4 hale-pope
hale-pope
    Advanced Member
  • Members
  • PipPipPip
  • 135 posts
Posted 13 September 2017 - 09:37 PM
HI - should i not disconnect the live and leave the negative in place or is that a daft thing to do?
#5 freddofrog
freddofrog
    won 16.4k on Euro lottery :)
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
  • LocationOff abroad
Posted 14 September 2017 - 04:50 AM
It doesn't make much difference, but the -ve is usually easier to access.
As already implied, it sounds like there's a serious electrical fault and you need to identify what has been dislodged (wiring, earthing points, modules)
#6 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
  • Car :2005 Tourer i-CTDi
Posted 14 September 2017 - 07:59 AM
The negative battery terminal is safer to remove than the positive terminal... if the spanner being used to loosen the positive connection accidentally brushes against something metal on the car during the removal then there'll be a giant spark! For the same reason, during battery removal the negative connection should be removed first (and then reconnected last during refitting).
I'm guessing that the shock of the collision has shaken loose a connector somewhere? Best to spend time disconnecting and reconnecting every connector you can find!
