NOTE: Before replacing the gauge control module, retrieve the ODO value and the service reminder system information from the gauge control module with the HDS.
Remove the driver's dashboard undercover, then remove the dashboard lower cover.
Remove the two bolts from under the dashboard, then pull the gauge control module (A) out carefully.
Disconnect the 32P connector (B) from the gauge control module.
Install the gauge control module in the reverse order of removal.
Write the ODO value and service reminder system information to the new gauge control module.
A B
This is the best I can offer, the drawings will not copy but it appears to pull out once the two bolts are removed. How you save the ODO and service info is a mystery
On the unit there is a small knob, that resets the odometer, it also controls the light output to the unit, by turning it you can have it very bright or off. Have you tried this??
