Thousands' driving without crucial diesel filters - BBC News
Status
Not open for further replies.
woodie
Trowbridge
2005 Accord Tourer
http://www.bbc.co.uk/news/uk-41761864
Thousands of motorists are breaking the law by driving diesel cars without pollution filters, experts have told BBC 5 live Investigates.
The Driver and Vehicle Standards Agency says 1,800 cars have been caught since 2014.
But experts say they believe the number is much higher, claiming the current MOT test, which requires only a visual inspection, is not fit for purpose.
The DVSA says it plans to introduce changes to improve the test next year.
All new diesel cars produced after 2009 have diesel particulate filters designed to reduce pollution levels, but they can sometimes get clogged up and break down, costing thousands of pounds to replace.
Because of the cost involved, some motorists are opting instead to have them removed.
It is illegal for drivers to use a car with the DPF removed, but it is not illegal for garages to take them out.
5 live Investigates followed the progress of a car which had its filter removed through MOT tests at three different garages.
Mechanics failed to spot the filter had been taken out on each occasion.
MOT 'not fit for purpose'
Frank Kelly, professor of environmental health at Kings College, London, said the health impact was devastating.
"If a DPF is removed, it takes the work being done to restrict emissions back 30 years.
"A car with a DPF removed has a particulate count 20 times higher than one with it.
"The particles lead to numerous health problems such as lung cancer, heart attacks, strokes, Parkinson's, Alzheimer's - and can also affect an unborn child in the womb."
Experts have told 5 live Investigates that the 1,800 cars which failed the MOT test since 2014 because the filter had been removed are just the tip of the iceberg.
They believe many thousands more are getting away with it because current emission tests do not always detect it, and another test - which involves only a visual inspection of the filter unit from the outside - is not adequate.
Nick Molden, chief executive of Emissions ****ytics, said: "It is clear a more detailed inspection of vehicles is required during MOT, and potentially spot-checking of vehicles in real world situations is needed, too.
"The MOT test is clearly not fit for purpose in checking if a DPF has been removed."
'Close the loophole'
Labour MP Mary Creagh, who is chairwoman of the environmental audit committee, said: "I'm concerned there could be tens of thousands of cars on the road which have had the DPF removed.
"The government should tighten MOT tests and close the legal loophole that allows garages to remove them and cheat the public out of clean air."
A spokesman for the Department for Transport said there were plans to improve the test to make it more effective.
A spokesman for the Driver and Vehicle Standards Agency said: "DVSA is making further changes to the MOT manual and to the diesel emissions limits for modern vehicles, in May 2018.
"These will make the test more robust and better able to detect where emissions control equipment has been tampered with."
this gonna be big news in motoring world nd it could effect second hand sales of all makes with dpf cos it big maintain cost
This has been discussed many times in many forums over the years. It was only a matter of time before this loophole was gonna be closed. Those not into cars will see it as major news, but for those who know about cars or are regularly in respective forums have always been aware of this grey area so to speak.
its not grey area, and loophole not going to be closed. loophole is that it legal to remove DPF but illegal to drive car with DPF removed, and that is like it being legal to import cocaine but illegal to use it. so only way to close loophole is making DPF removal illegal, but that not on the cards.
they say that they will make mot test better but if DPF is removed good it not possible to see, so it will make mot test for diesel much longer to check outside of DPF, other way is like link from slimsonic , use OBD but it gonna need special OBD tool to check all ECUs
Forgive me, I'm not up to speed on exactly how the DPF works, but could the lack of a DPF be detected by ****ysing exhaust fumes? Or that an over-simplistic understanding of it?
DPF is big sive in canister, as in one link of slimsonic, some cut hole in side and remove guts then weld plate over hole, and some open seam and close seam good, but DIY merchant could buy cheap aftermarket DPF, get guts out through the pipe ends, and replace empty aftermarket one onto exhaust. when guts are removed the ECU need remap that is only way to see.
diesel exhaust fumes produce lot of particles when car driving along road, not enough when car tested in garage, but one link of slimsonic say new mot might do test in garage at high rpm and many minutes
Nothing new here. Easy to dispel a lot of the drivel being pushed in that article, but it's been covered so many times.. I don't think anyone can be arsed.
Status
