Jump to content
2.2 ctdi idel problem and cutting out
  • Please log in to reply
26 replies to this topic
#1 slim
slim
  • Members
  • PipPip
  • 15 posts
  • Name:simon
  • Car :accord sport
  • Locationdurham
Posted 08 November 2017 - 04:22 PM
Idles from 800 to 1000 and under braking revs drop and cuts out but starts back up straigh away. Any help appreciated thanks
#2 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 864 posts
  • Name:Stephen
  • Car :Accord 7 Estate 2005
  • LocationKT8 Postcode
Posted 08 November 2017 - 08:02 PM
What have you tried already ?
Have you drained the fuel filter to see what comes out ?
#3 slim
slim
  • Members
  • PipPip
  • 15 posts
  • Name:simon
  • Car :accord sport
  • Locationdurham
Posted 09 November 2017 - 12:43 PM
Iv give it a full service all fillters cleand egr. Found a vac pipe with tiny hole so replaced just went for mot passed. Just not sure why its bad idle also has no engine lights even when it cuts out thanks for reply
#4 slim
slim
  • Members
  • PipPip
  • 15 posts
  • Name:simon
  • Car :accord sport
  • Locationdurham
Posted 09 November 2017 - 12:47 PM
Wile under bonnet think exhaust manifold leaking so ordered cast one replacing this weekend. But i dont think that would cause the idel problem??
#5 Acowner
Acowner
  • Members
  • PipPip
  • 16 posts
  • Name:Pete
  • Car :Accord
  • LocationJ23M1
Posted 09 November 2017 - 07:23 PM
ref exhaust manifold, maybe a rumour, but if the car is under 126,000 miles Honda may cough up. There's a contact form on the Honda website to ask the question, dealers, need I say more!!
#6 Cliffordski
Cliffordski
    And still...
  • TA Friends
  • PipPipPip
  • 1,432 posts
  • Name:Cliff
  • Car :06 Tourer 2.4 EX man
  • LocationCounty Durham
Posted 09 November 2017 - 09:01 PM
I'm from Durham as well so PM me with your address and mobile no. and I'll come round and read the engine fault code for you.
  • honda_saj likes this
#7 slim
slim
  • Members
  • PipPip
  • 15 posts
  • Name:simon
  • Car :accord sport
  • Locationdurham
Posted 13 November 2017 - 10:15 AM
Manifold done still the same idle. Found if i prime fule bulb while running she runs fine stop primeing and surge comes back thanks again
#8 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 864 posts
  • Name:Stephen
Posted 13 November 2017 - 07:06 PM
You either have an air leak, or the filter is blocked.
Did you run the tank to  - almost - empty ?
Has this started happening after one particular fuel stop ?
Edited by Channel Hopper, 13 November 2017 - 07:07 PM.
#9 slim
slim
  • Members
  • PipPip
  • 15 posts
  • Name:simon
  • Car :accord sport
  • Locationdurham
Posted 13 November 2017 - 07:47 PM
Did run low when i got car. replaced filter since but not with genuine so ordered genuine should be here friday. Thanks again for all the help
#10 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 864 posts
  • Name:Stephen
Posted 13 November 2017 - 09:04 PM
I had trouble with the drain seal under the filter canister that came with the car (checking for water)
My fault of course but you might find there is a similar leak in the bottom seal, or possibly the 10mm nut (or connecting pipes)  up top.
Did you check the earlier filter for water/debris when you replaced it  ?
#11 slim
slim
  • Members
  • PipPip
  • 15 posts
  • Name:simon
  • Car :accord sport
  • Locationdurham
Posted 13 November 2017 - 09:13 PM
It all seems dry will have a look tommorow old filter was dirty and genuine. Problem now happens all the time cold/hot but drivrs really well only on idel shopping
#12 slim
slim
  • Members
  • PipPip
  • 15 posts
  • Name:simon
  • Car :accord sport
  • Locationdurham
Stopping
#13 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 864 posts
  • Name:Stephen
Posted 13 November 2017 - 10:56 PM
What mileage ?
#14 slim
slim
  • Members
  • PipPip
  • 15 posts
  • Name:simon
  • Car :accord sport
  • Locationdurham
Posted 14 November 2017 - 05:47 PM
Reading 155k but had new engine fitted 3years ago so millage wont be right i wouldnt have thought. All i can think is fule filter or pump but drives really well apart from idle. No leak on filter houseing ether thanks again
#15 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 864 posts
  • Name:Stephen
Posted 14 November 2017 - 08:32 PM
Not a problem. I'm also wondering - from previous experience on other vehicles - if you might have a loose electrical connection somewhere.
Have you had the radio reset / lose tune, at any point when you have not disconnected the battery deliberately ?
Edited by Channel Hopper, 14 November 2017 - 08:32 PM.
#16 slim
slim
  • Members
  • PipPip
  • 15 posts
  • Name:simon
  • Car :accord sport
  • Locationdurham
Posted 14 November 2017 - 08:51 PM
No problem with radio or anything else think its fule related not sure tho. If i prime bulb while running the engine runs fine stop primeing rough idel or cuts out. Starts straigh back up no lights just bad idle. Will drive fine and boost in all gears just when stopping cuts out idles real bad. Scraching head lol thanks again
#17 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,121 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 14 November 2017 - 10:49 PM
I would have said Honda hds to check out
Regards,
saj
#18 slim
slim
  • Members
  • PipPip
  • 15 posts
  • Name:simon
  • Car :accord sport
  • Locationdurham
Posted 15 November 2017 - 05:47 PM
Yes i would agree but no engine lights or faults with plug in. Im hopeing its the fule filter is new but crossland make i think genuine one should be here on friday. Thanks again for all the help
#19 brett
brett
    T A Terminator
  • Administrators
  • 13,669 posts
  • Name:Brett
  • Car :8th gen 2.4 Manual
  • LocationBristol
Posted 15 November 2017 - 06:18 PM
Also one to try is cleaning your MAF sensor with the correct spray.
I had this on my car by the revs were fluctuating when I was stopping at junctions and traffic lights.
I no mine is a petrol but for the price of a can of spray it’s good maintenance as well.
 photo IMG_06551_zps16877260.jpg photo 1a30ead12b5799ee4c7f519123a797de_zps2vsu5cen.jpg
#20 edgeoftime
edgeoftime
    Advanced Member
  • Members
  • PipPipPip
  • 1,799 posts
  • Name:John Hamer
  • Car :11 idtec tourer ex.
  • LocationWaltham Abbey Essex
Posted 15 November 2017 - 09:36 PM
http://www.mister-au...CFdLItAodcQUAbA
get a bosch filter from him above.
http://www.mister-au...26!402!063.html
Edited by edgeoftime, 15 November 2017 - 09:38 PM.
