Abs light issue help!
Thej
Tyne and Wear england
2002 Honda accord
I have just replaced my exhaust system, front, middle and back, I then started up the car to check every thing was all good and my abs light has stayed on! The only time recall touching anything to do with brakes was when I was underneath I noticed the the rubber where the handbrake cable enters the car wasn't seated right. I may have give the cable a little jiggle then thought "that's for another day" and left it at that.
The car was still jacked up at the front end and also off side rear when I started it up. Could this have caused the light to stay on if 3 wheels were raised off the ground??
Sent from my iPhone using Tapatalk
Hi, your best bet and quickest/cheapest way is to find someone with the Honda diagnostic to plug in, Honda dealer would do, but properly not tell you the exact fault, but a high price to fix. or if upto it, the wire in the diagnostic plug, cannot remember the pin numbers, then count the flashes on the dash if it works, theres other posts on VSA light to find the pin numbers.
