mdrab
[SIZE=10.5pt]Hello,[/SIZE]
[SIZE=10.5pt]Just new to this forum.[/SIZE]
[SIZE=10.5pt]My car was working fine for 3 months then my key fob stopped working when I went to lock it.[/SIZE]
[SIZE=10.5pt]So I changed the battery in the key. Then it working straight away to unlock the car got in went home from work and locked the car as normal.[/SIZE]
[SIZE=10.5pt]The next day went out to unlock the car and it stopped working again, So I unlocked it manually on the drivers door then the hazards started flashing like mad but the horn wasn’t going off.[/SIZE]
[SIZE=10.5pt]So I found out you do that unlock lock thing with the key in the driver's door which turned it off.[/SIZE]
[SIZE=10.5pt]And then my key fob would work sometimes and stop again.[/SIZE]
[SIZE=10.5pt]Now it just doesn't work at all however the boot button will work everytime.[/SIZE]
[SIZE=10.5pt]And I need to leave the car unlocked all the time. As it is a right pain to turn the alarm off.[/SIZE]
[SIZE=10.5pt]I have reprogrammed the key to the car a number of times. Bought a new key and done the same thing but the car will still not unlock or lock.[/SIZE]
[SIZE=10.5pt]I have checked that all doors are closed.[/SIZE]
[SIZE=10.5pt]Done the disconnect battery and back on.[/SIZE]
[SIZE=10.5pt]I really don’t know what else to do?[/SIZE]
[SIZE=10.5pt]Help please?[/SIZE]
