soava
Hi,
My name is Florin and I want to ask you something about my Honda Accord CL7, sedan, 2008, 2.0 Petrol, 155HP, MT. I changed my clutch kit a few months ago, it was ok 1,2 months. After this it started sleeping again. Then I changed the master and slave clutch cylinder. It's ok, the car accelerates ok but the clutch pedal is not so smooth like a pedal in a new car and if I use the car for tens of miles pedal starts to be harder to press. I know the mechanics who changed the clutch kit didn't clean the box clutch and didn't lube the zones in the clutch parts, only the bearing was lubed. Can be the problem because of this? Do I need to open and clean, lube the clutch as it is normal?
If you know a mechanic here, on the forum please tell me.
Thank you and sorry for disturbing you
Apologize for my English
