Accord-EX
I replaced my battery with a genuine Honda one about 3 years ago and its working fine and shows the green indicator in the peep hole
When Im parked up in my car and leave the car key on the final setting with the engine stopped it seems to drain the battery down in about 10 minutes or so. I've removed the HFT unit which sometimes can cause drain issues so its not that. If I then get the car started and drive for a while it works as normal again. So alternator/battery etc seem fine, but there is something running it down quickly with the key in... any ideas??
