Is it safe to weld on car?
accord1108
Eire
Ex 2.2 i-Dtec
Hello,
Firstly i will give a bit of background, i bought my car to get the alignment done, they tried adjusting the toe arm on one side at the back, however they couldn't set it . They advised that it was the bush in the arm, that was gone. Ive had the arm out since, and the bush looks ok, what i think the fault is, is the tab which the CAM bolt pushes against was forced, and its now bent, it can be straightened back, however it is broke and wont hold.
If put back in the correct position and held with a small weld on one side i think it should be ok.
My reason for this thread, is i want to know is it safe to weld on these cars, before i take it to someone to weld.
could the ECU be damaged?
My other option is to fit adjustable toe arms.
Disconect the battery. That's it
Poslano z mojega ASUS_Z016S z uporabo Tapatalk
