Jump to content
Silent block replacement in the lower control arm
  • Please log in to reply
11 replies to this topic
#1 dandreye
dandreye
  • Members
  • PipPip
  • 44 posts
  • Name:.
  • Car :Accord 2L MT (CL7)
  • LocationLondon
Posted 15 February 2018 - 11:56 AM
Hi All,
Has anyone tried removing old silent blocks from the lower control arm and fitting new ones using this type of tool kit marketed for ball joint replacement:
https://i.ebayimg.co...Exb/s-l1600.jpg
If so how much effort/time did it take you and are there any critical do's and dont's to be aware of?
I need to do both lower ball joints and lower control arm silent blocks and hoping that that single kit will spare another £75-100 that press and pull sleeve kits cost.
Many thanks in anticipation!
Edited by dandreye, 15 February 2018 - 03:32 PM.
#2 Cliffordski
Cliffordski
    And still...
  • TA Friends
  • PipPipPip
  • 1,448 posts
  • Name:Cliff
  • Car :06 Tourer 2.4 EX man
  • LocationCounty Durham
Posted 15 February 2018 - 08:49 PM
Just buy new arms with new bushes already fitted - and save yourself a lot of blood, sweat and tears.
#3 dandreye
dandreye
  • Members
  • PipPip
  • 44 posts
  • Name:.
  • LocationLondon
Posted 15 February 2018 - 10:15 PM
We're not looking for easy ways :D
The reason for asking is that (1) the kit in question is at least twice cheaper than the labour and I need it to do the ball joints anyway and (2) having an office job I usually go for that sort of activities as a gym substitute. Buying arm assemblies complete with the bushes has been an obvious alternative since inception, I'm just researching if it's really that hard to swap the bushes alone with this or perhaps a more suitable tool, e.g. one of those press and pull sleeve kits. I fancy investing into various useful tools the money that'd otherwise be, well, wasted )
Edited by dandreye, 16 February 2018 - 01:01 AM.
#4 Cliffordski
Cliffordski
    And still...
  • TA Friends
  • PipPipPip
  • 1,448 posts
  • Name:Cliff
Posted 16 February 2018 - 06:16 PM
If you want a challenge why bother with the kit - just pull them out with your teeth.
If the bushes have seized in the arm then you can hacksaw the metal surround off the compliance bush and remove them that way. But if the others are seized they might need pressing out with a hydraulic press at a garage. Some people just change the compliance bush only when they do this job.
Up to you but having tried it the hard way myself I'd still recommend new arms.
#5 dandreye
dandreye
  • Members
  • PipPip
  • 44 posts
  • Name:.
  • LocationLondon
Posted 16 February 2018 - 07:21 PM
Thank you: fair enough. I couldn't resist the temptation to buy a MOOG one (decent quality reportedly) at this kind of pricing:
https://www.ebay.co....tm/142115321005
Sadly they don't stock the other one but I hope I don't have to have the same brand at both sides and will then get something else I trust, e.g. Borg & Beck at GBP50 or Blueprint at GBP60 for the total of just over GBP70-80 for both resp. The 4 bushes alone would cost me at least GBP35 total, so not that much of a difference anymore.
Also that way I'll have as much time playing with the bushes in the old ones afterwards as I want )  After watching a couple of bush replacement videos on Youtube it looks like hacksawing is going to be necessary indeed unless WD-40 and that toolkit do wonders.
Update: do the lower arms in my car actually have compliance bushes at all? There are only 2: the inner one for frame attachment and the outer one for the strut fork attachment. Looks like compliance bush is the 3rd one where it exists.
Edited by dandreye, 16 February 2018 - 07:44 PM.
#6 Cliffordski
Cliffordski
    And still...
  • TA Friends
  • PipPipPip
  • 1,448 posts
  • Name:Cliff
Posted 16 February 2018 - 07:52 PM
No - I'd assumed you have a 7th Generation Accord.
As investments go I've found this https://www.ebay.co....PQAAOSwkLhaTQnQ invaluable for removing corroded fasteners.
#7 dandreye
dandreye
  • Members
  • PipPip
  • 44 posts
  • Name:.
  • LocationLondon
Posted 16 February 2018 - 09:25 PM
I purchased a similar Campingaz one several years ago after watching them easily undoing all those 15-year old rusted bolts and nuts on my car with a similar tool at a garage, none of which I had any luck undoing by brute force:
http://www.ebay.co.uk/itm/370562521562
It's been extremely helpful ever since. The only frustration was to discover these ones later as they're 10 times cheaper and probably still good enough for the job:
https://www.ebay.co....tm/273015950580
https://www.ebay.co....tm/253334972008
They fit traditional tourist butane gas cans sold everywhere although yours (and mine) with a threaded connection can do too via an adapter (purchased, tested, works):
http://www.ebay.co.uk/itm/332228685709
Thanks for the idea anyway: absolutely agree it's a must have for any old car to avoid that blood, sweat and tears )
Edited by dandreye, 16 February 2018 - 10:06 PM.
#8 Thej
Thej
  • Members
  • PipPip
  • 27 posts
  • Name:Keith
  • Car :2002 Honda accord
  • LocationTyne and Wear england
Posted 15 April 2018 - 02:19 PM
Sent from my iPhone using Tapatalk
#9 Thej
Thej
  • Members
  • PipPip
  • 27 posts
  • Name:Keith
Posted 15 April 2018 - 02:24 PM
on this subject!
I planned on replacing just the bushes and yes a right mission. Moog replacement bushes only the inner fit, the outers are too small so car is currently up in the air in bits. Anyway regarding lower control arms can anybody answer this: why is there 40mm difference in length of lower control arms for cars manufactured in Japan or USA and Uk?
Edited by Thej, 15 April 2018 - 02:25 PM.
#10 Cliffordski
Cliffordski
    And still...
  • TA Friends
  • PipPipPip
  • 1,448 posts
  • Name:Cliff
Posted 15 April 2018 - 10:07 PM
Same name but different car.
#11 exec
exec
    Advanced Member
  • Members
  • PipPipPip
  • 1,703 posts
  • Name:Exec
  • Car :'99 2.0 SE Exec
  • LocationLondon
Posted 16 April 2018 - 12:30 PM
They were different length, the cars, for example the JDM Accord I believe was shorter.
In VTEC, we trust.
#12 Salim
Salim
  • TA Friends
  • PipPipPip
  • 1,827 posts
  • Name:Sal
  • Car :Accord
  • LocationSW
Posted 16 April 2018 - 01:17 PM
Hi All,
Hi All,
Cant answer but i do have this kit and pulled all the bushes out of my 20+ yr Toyota to replace with poly bushes.
The kits decent and robust and will pull out most bushes/joints if you have the right adapter combo- which can be a faff. I also have a assortment of press plates so can use them if the kit doesnt have the right size.
can make the job easier (if theres room) than having to pull the whole assembly to put it on the press. . grease the threaded bar though, I used a impact gun which made it easy.
