Jump to content
Battery losing charge
battery leak off flat
  • Please log in to reply
6 replies to this topic
#1 Biggles
Biggles
    Newbie
  • Members
  • Pip
  • 11 posts
  • Name:Rick
  • Car :Accord EX
  • LocationGloucestershire
Posted 19 February 2018 - 01:49 PM
I hope someone can help with my problem, 2006 Accord 2.2 Diesel Exec Tourer.
When leaving  my car unused for a couple of days the battery is well drained down & won't start sometimes. The alternator is charging fine, Battery is only a year old so no trouble there. I tested for a drain on the battery by using a 3w bulb wired between the battery post and the battery cable (disconnected). The light bulb was lit which shows current being used, I then removed each fuse from the interior fusebox in turn until the bulb went out. It went out when fuse No. 7 was removed, according to the handbook this fuse is for back up, ( I assume that means reverse lights). The reverse light is working fine, I disconnected the bulb but still had leak off.Has anybody got any idea what could be using current on this circuit?  I don't know if it's related but the HFT and the power socket in the centre consul stopped working some time ago, also I fitted a reverse camera years ago, that's working fine. I also checked for leak off with the HFT module disconnected and that made no difference. Any help welcomed..
Edited by Biggles, 19 February 2018 - 02:04 PM.
#2 mtecally
mtecally
    Newbie
  • Pre-Members
  • Pip
  • 1 posts
  • Name:Alisdair Clarke
  • Car :accord
  • Locationayrshire
Posted 19 February 2018 - 04:59 PM
Had a very similar issue just last few weeks. Disconnected the Bluetooth module and not had a problem since
Sent from my iPhone using Tapatalk
  • jon.moreby likes this
#3 jon.moreby
jon.moreby
  • Members
  • PipPip
  • 29 posts
  • Name:jon moreby
  • Car :accord tourer 05
  • Locationchichester
Posted 19 February 2018 - 06:56 PM
Mine had battery issues after fitting parrot. Lots of battery issues have been affected by Bluetooth modules. Saying that tho, if you don't have a Bluetooth fitted, you'd be back to square one!
Edited by jon.moreby, 19 February 2018 - 06:57 PM.
#4 Biggles
Biggles
    Newbie
  • Members
  • Pip
  • 11 posts
  • Name:Rick
  • Car :Accord EX
Posted 19 February 2018 - 11:53 PM
I realize now that fuse 7 named as "back up" does not mean reverse lights lol. I did disconnect the bluetooth module behind the panel where the hazard light switch is but there was still a drain on the battery. Tomorrow I will leave fuse 7 out and see what doesn't work
#5 chrisv
chrisv
    Newbie
  • Members
  • Pip
  • 11 posts
  • Name:chris vincent
  • Car :accord tourer 2006
  • LocationTeesside
Posted 23 February 2018 - 03:39 PM
I’ve been trying with mine for five years. I always carry a spare battery. I find it’s not quite as bad if I turn the air con off. It has had 3 alternator and 3 batteries
Sent from my iPad using Tapatalk
#6 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 903 posts
  • Name:Stephen
  • Car :Accord 7 Estate 2005
  • LocationKT8 Postcode
Posted 24 February 2018 - 11:01 PM
Same here, though I also carry a small set of jump leads, saving swopping over the ******* thing whenever it wants to play silly ******s.
  • chrisv likes this
#7 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,152 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 26 February 2018 - 07:48 AM
You need to do load test with meter
Regards,
saj
Also tagged with one or more of these keywords: battery, leak off, flat
