MTF Oil change
looney
Riga
CL9
Are there any videos or good DIY with pics how to change MTF?
Where are the drain and fill plugs located?
Internet is full of US version accords, but no single one Euro 7th gen. :(
Thanks!
2007 Accord (facelift)
I see that my fill plug is 'upright' position in engine bay besides the air box. Not 'side' position as in the links... so cannot just fill till it goes out.Or can i? How many do i need to top up?
I have read that 2.1L is enough? Is it?
Transmission code BWG6-5001101 (6 speed manual)
There is also a level plug on the side as well as the fill plug on the top.
You need to remove the level plug and then fill it until it runs out of the level plug.
Jep! tnx! Got it! Changed the oil successfully! :) Thanks! I filled 2.5L in the box untill it started to run out.
