Jump to content
PGM-FI, Glow Plug Curcuit Open
  • Please log in to reply
3 replies to this topic
#1 Simkin
Simkin
  • Members
  • PipPip
  • 32 posts
  • Name:Tore
  • Car :2009 Accord
  • LocationNorway
Posted 12 March 2018 - 06:02 PM
I changed all my glow plugs some months ago (ORIGINAL HONDA) and everything have been fine since then.
However, the PGM-FI lamp has come back and i read out the first time; Glow Plug Curcuit Open on Plug 2 and 4. I suspect the wiring/connector, took them off and tighten the metal with pliers, put it back on and the glow plug fault code on cyl 2 seems to have gone away, but on cyl 4 it comes back.
The connector is not directly loose, but not super tight either, but i suspect this is the cause of the fault code, but really dont know how to make it tighter than it is now.
Anyone with similar issues? Are they very "sensitive" to have good contact on the glow plugs?
Edited by Simkin, 12 March 2018 - 06:04 PM.
#2 TourerFan
TourerFan
  • Members
  • PipPip
  • 57 posts
  • Name:Pete
  • Car :idtec tourer manual
  • LocationWakefield
Posted 16 March 2018 - 06:51 PM
Hi Simkin,
have you checked the multi-plug for the glow plugs, it's fastened to the metal plate between the battery and the headlight unit.
I ask this because I removed this metal plate and the battery when trying to change a headlight bulb, and I got PGF-F1 when i had finished.
The multi-plug was not fully engaged.
Pete.
#3 Simkin
Simkin
  • Members
  • PipPip
  • 32 posts
  • Name:Tore
  • Car :2009 Accord
  • LocationNorway
Posted 13 April 2018 - 08:37 PM
Little late reply but;
The problem was actually a lose glow plug on cylinder 4. Its tight space around the glow plug on the fourth cylinder so the socket that i used to tighten the glow plug actually got a little stuck if i put it all the way down over the glow plug, so when the plug felt tighten it was actually just touching/get stuck on the metal on the cylinderhead instead.
Had to clean out the glow plug hole as it had accumulate soot and gunk there due to the plug beeing lose, but its tighten correctly now :)
Edited by Simkin, 13 April 2018 - 08:39 PM.
  • honda_saj likes this
#4 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,125 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 14 April 2018 - 08:56 AM
great thanks for update
Regards,
saj
