Wheel size
Aurimasas
Lithuania
Accord 2005 2.2
Hi guys,
Couldnt find same topic so just want you to ask. Are wheel parameters (bolt circle, center hole) are the same for pre facelift and facelift? I am searching for rims for my 2005 saloon so Im just wondering if those will fit from the face lift. Bolt circle should be 114.30 as far as I know. Thanks
Yep same across the range.
64.1mm centre bore
Et55 offset
114 x 5 pcd
Hi again,
Just bought new rims. One question I have - are they OEM and if they have any kind of name/manufacturer? Pictures attached.
Yes they're OEM honda rims. They might be Enkei but I'm not 100% confident on that one
