How to remove boot trim on hatchback
2lexec
uk
Honda
I have a water leak in the boot of my 52 plate Accord hatchback, last of the hatchbacks I think.
How do I remove the panels inside the boot that fit next to the rear wings?
I thought I'd fixed the leak but no, does anyone have any ideas where the water could be coming from.
The base of the nearside cubby hole in the boot is very wet and then I think water goes into spare wheel well.
appreciate any advise
2lexec
The lights are usually common culprit, failed seals and clogged drain holes.
thanks exec, this may sound a silly question but where are the drain holes?
Apart from Honda, do you know anywhere to get the seals? When I tried Honda the seal came with the
light cluster at nearly £80
If the seals have gone, any ideas what I can used if I cant get seals at a reasonable price?
thank you
2lexec
