Hi All,
I've been getting check system message & glow plug light flashing on the car, which is a P1704 code - Clutch Pedal switches.
I know there are two switches and Honda want £70 for the pair ! (Swears loudly!!!)
I've been driving around no problem with the check system message & glow plug light flashing constantly, sometimes it goes off but it returns after a while.
Strangely enough, clutch changes can be a bit jumpy, especially when changing from 1st to 2nd gear, but car still pulls ok with the usual hesitation/lag (MIL).
I'm planning on changing the car at the end of the year as its nearing 200k miles, should i need to change these switches or will they last? It does make the drive around town a bit uncomfortable, but am i in danger if i leave the switches??
Serg.
Serg.
