Nope.. pre facelift is all one unit. Facelift has a filter separately attached to the vacuum line. The whole setup for the intake and egr is different on pre and post facelift.
If you're having imrc issues I would suggest your intake is blocked. Changing the imrc might give you some temporary relief but the new part will eventually weaken and fail too.
Better off removing intake, thoroughly cleaning out, blanking egr off and remapping.
