Will it fit (speakers)
Aurimasas
Lithuania
Accord 2005 2.2
Hi,
Today I took out 4 speakers from my old mitsubishi colt. I am now thinking is it worth to put them to my 2005 accord saloon which has premium sound system. Maybe someone knows what are OEM Speakers and their parameters in front and back door? I saw that in the trunk its Pioneer but I do not want to take the door panel for no reason. Pictures of my old speakers below:
Not sure if this is any help to you...
http://jmp.sh/mLDrAMu
Part way down it shows the REAR door speaker with its clip and lug fitting. I'm not sure if the fronts are the same, but I'd imagine so. You might need to adapt your speakers / drill the door to suit?
Hi Matt,
Thank you for the post and help. I think it should be the same like in front. If the OEM honda speakers are 6,5in it will fit perfectly.
Where can I find the specs of OEM speakers? I do not want to take it out for no reason if they are better than these Alpine's I have. If OEM are better, its not worth changing it.
