Front compliance bushes..!
Bongobiker
Kent
Accord Tourer 2.4
Does anyone know the part number for the large bush at the front on the lower arm? I have found some on e-bay 51391-SEA-004 but wanted to check first.my car is a 2003 2.4 Tourer.
I believe you can get Polly ones but have not managed to find any.
I fitted PSB bushes, very easy to fit and have worked very well since I replaced mine a few months ago.
The hardest part for me was the n/s front bolt for that bushing, the bolt was seized in place and had to be heated and turned with a long breaker bar to get it to release.
Once the old bushes were pressed out and the arm cleaned the new ones went in with only small effort.
They have really firmed up the handling now but not uncomfortably so.
These are the ones:
https://www.ebay.co.uk/itm/2-x-Honda-Accord-Front-Lower-Rear-Control-Arm-Polyurethane-PSB-Bush-2003-2008-/172566049119
Those are the small rear ones on the front lower arm, I need the big ones at the front..!
No, those are the big ones at the front they don't make the small ones for the other two bushes.
The diagram on the page is wrong.
The ***le even says "Front Lower Rear Control Arm Polyurethane PSB Bush" and you can't even ask the seller a question..!
Are you saying it's this one?
