partha9797
Hi all, I'm having some major problems with my Honda Accord (2.4 iVTEC E - 190hp) one morning it wouldn't start and only started when your foot was mashed down on the accelerator pedal.
When it does run the engine misfires terribly and the whole engine shakes because of it (some white smoke out of the exhaust).
We took it to the garage and we suspected a timing issue so the front and rear camshaft sensors were replaced.
No change.
The spark plugs were replaced and then the engine oil level were checked; no change.
Then the fuel pump was changed, again no change.
My next port of call is to open the engine up and take a look at the timing chain, would this be the right thing to do?
Could it be anything else, open to any suggestions.
Any advice and guidance would be hugely appreciated!
Thanks in advance!
Sent from my Moto G (4) using Tapatalk
No change.
Thanks in advance!
