Jump to content
Disappointed
  • Please log in to reply
14 replies to this topic
#1 firedup
firedup
    Newbie
  • Members
  • Pip
  • 4 posts
  • Name:andrew chaisty
  • Car :accord cdti
  • Locationandalucia Spain
Posted 07 June 2018 - 01:40 PM
Hi.
Bought a 2004 Accord Cdti. Intending to keep it a couple of years.
But its not come up to expectations. Engine is supposed to be modern, state of the art when launched. Well it isn't.
Its doesn't get quiet until cruising, when its fine. My friends 2005 Kia Diesel, is a lot quieter.
It has two notable power surges. One about 1500 revs, other around 2300-2400 revs. I know it has a two stage turbo.
But off boost, its a joke, absolutely no torque. An old Skoda 1.9 TD, has much more usable torque. 2nd to 3rd not good. 3rd is too high unless you rev it out in 2nd.
Drivers seat is set too high, even on lowest setting. Means rear view mirror obstructs view.
Handling is so-so. Doesn't like to turn in unless you force it. Grip ain't good for size of tyres. Mondeo kills it.
Let's wind in at speed. Suspect tired door seal.
Are these things described, typical? Iam looking for a replacement. Is the 8th Gen better? Upgraded engine with horrid dpf. Fancy 180bhp model. Is the engine much better in next Gen?
Andrew
#2 Mr Honda
Mr Honda
    Advanced Member
  • Members
  • PipPipPip
  • 1,280 posts
  • Name:Honda
  • Car :Accord
  • LocationEire
Posted 07 June 2018 - 01:48 PM
sounds like you bought a tired old brute, the 2.2 was whisper quiet (google reviews of Honda whispering diesel) as a newly launched Honda diesel, though if you want clatter free buy a petrol engine. The later 8th gen was much improved but still a diesel, so can get coked up with s****e too and yes the DPF is still another thing to consider if the car has had a bad life.
#3 Matt
Matt
    Advanced Member
  • Members
  • PipPipPip
  • 833 posts
  • Name:MattW
  • Car :CW3 Facelift ES GT
  • LocationYorkshire
Posted 07 June 2018 - 04:38 PM
Perhaps a test drive of your prospective 14 year old car next time, before you part with your money?
Edited by Matt, 07 June 2018 - 04:42 PM.
#4 firedup
firedup
    Newbie
  • Members
  • Pip
  • 4 posts
  • Car :accord cdti
Posted 07 June 2018 - 07:18 PM
Sarcasm I could do without.
I drove the car on the flat, and it felt OK. And no, they are not that quiet for a diesel. Tested a few. Its not tired, or a dog. Maybe I was expecting more.
If you drive it hardish, it goes well, but let it off boost, that's the issue, especially going up hill. Engine is just flat, nothing until boost. And no, they all seem like that. That's why I asked if they have improved the bottom end torque, and gap in 2nd to 3rd. 6 speed gearbox should close the gap?
Its going in for a service, will ask them to check the turbo, and adjust the tappets. See if that changes things.
I want to like the car. Its well built, with a nice closed clunk on the doors, panel gap is good. Being a tourer, boot space is brilliant. One of the best things about the car.
#5 Cliffordski
Cliffordski
    And still...
  • TA Friends
  • PipPipPip
  • 1,450 posts
  • Name:Cliff
  • Car :06 Tourer 2.4 EX man
  • LocationCounty Durham
Posted 07 June 2018 - 07:42 PM
If you want more poke, get a remap, simple as.
#6 F6HAD
F6HAD
    Affiliate / Co-Founder
  • Administrators
  • 12,847 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 07 June 2018 - 09:47 PM
Sorry to hear you're disappointed with your purchase, but it is afterall a 14 year old car.
It doesn't have a 2 stage turbo, what you're experiencing is more likely sticking egr valve and intake manifold.
Solved with an egr off and remap.
A service is a good idea, ensure the fuel filter is done and make sure it's a genuine honda dealer item.
The vw PD engines are great and have a lot of mid range grunt, but they're not a match for the refined ictdi,
Your tappets are pre set, they don't need adjusting. If it's noisy then more likely a rattling timing chain, cracked manifold or leaky injector.
Good luck.
Posted Image
#7 shubh83
shubh83
    Newbie
  • Members
  • Pip
  • 13 posts
  • Name:shubh
  • Car :accord dtec
  • LocationGB
Posted 07 June 2018 - 11:52 PM
An 04 accord something is not right, the 5 speed was a brute of powerful diesel easily capable of outrunning bigger engines, I recall overtaking a c300 V6 Merc (when he did not want me to). I had an Octavia as well but the first diesel accord was something very special.
Sent from my CLT-L09 using Tapatalk
#8 TypeR
TypeR
    Iron Man
  • Administrators
  • 5,880 posts
  • Name:Honda Guy
  • Car :Accord 05 Exec cdti
  • LocationWest Yorkshire
Posted 08 June 2018 - 01:35 AM
Does sound like you have bought a bad one. These cars are awesome if looked after and by far this is one of the best diesels of its time.
Maybe get some diagnostics done it to determine if it has a problem.
Honda Accord 2.2 I-CTDI Executive with Premier Tuning Stage 1 EGR OFF 18" Storms, LED number plate lights, LED sidelights, HID 4300K and X carlink with bluetooth handsfree. Diesel Power
#9 firedup
firedup
    Newbie
  • Members
  • Pip
  • 4 posts
  • Car :accord cdti
Posted 08 June 2018 - 07:09 AM
What I meant by 2 stage is, if you part throttle around 1500-1700 revs, you here it release boost. Then it goes to around 2400 revs, when it boosts again. I presume this is due to the vanes moving, increasing pressure. Is this correct?
#10 Cliffordski
Cliffordski
    And still...
  • TA Friends
  • PipPipPip
  • 1,450 posts
  • Name:Cliff
Posted 08 June 2018 - 08:53 AM
No
#11 F6HAD
F6HAD
  • Administrators
  • 12,847 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 08 June 2018 - 08:01 PM
Nope. If you can actually hear it dumping boost then you either have a boost leak or the egr is sticking open and you can hear it blowing past the valve. There's obviously an underlying issue, and given it's age that's not unreasonable to expect.
Everything is fixable, it's all about how much time and money you're prepared to spend.
Posted Image
#12 antdad
antdad
    Advanced Member
  • Members
  • PipPipPip
  • 110 posts
  • Name:Tony
  • Car :Tourer i-cdti 07
  • LocationHeathrow
Posted 10 June 2018 - 03:55 PM
Would an egr/turbo cleaner run through the intake help?
#13 F6HAD
F6HAD
  • Administrators
  • 12,847 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 10 June 2018 - 07:52 PM
Possibly but really it needs cleaning the intake and blanking egr.
Needs diagnostic before anything though
Posted Image
#14 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,152 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 10 June 2018 - 09:30 PM
good points fahad the only thing i would add is throttle body clean as well.
Regards,
saj
#15 Richard B
Richard B
    Advanced Member
  • Members
  • PipPipPip
  • 295 posts
  • Name:Richard
  • Car :2006 Tourer
  • LocationAustralia
Posted 13 June 2018 - 04:24 PM
There's a little bit of tractor in every diesel.
