PSF advice please
antdad
Heathrow
Tourer i-cdti 07
It needs topping up asap but the level shouldn’t have dropped so the system is leaking from somewhere. Maybe from a corroded pipe or where a pipe connects to the steering rack.
Yep fix the leak, it's a sealed system you should never lose a drop.
You guys were right I was just wishing it wasn't true. To my untrained eye it looks like the gasket has failed between the rack and the feed pipe bracket or is it more likely to be the end seal? Thanks for any advice.
I would say that's the internal seal that's failed mate. Hard to say from one picture.. get a mechanic to check it properly
