Hi guys,
So I was driving from Cornwall back to ol' Leeds and my air con stopped working unfortunately. I took it to the garage who said the compressor wasn't working on initial inspection. They have now done an actual diagnostic and found that the A/C itself is working but the message to turn on is not being sent from the dashboard/centre console itself. Via the screen which everything else works fine you turn it on and there is no response, also with the air con 'auto' etc. for climate control below it on the centre console. We've debated to avoid heavy costs potentially rigging a switch that will just turn air con on via a separate relay. Any ideas if this has been done before, or if this problem has a less costly solution?
