Jump to content
P2004 advice please ?
  • Please log in to reply
11 replies to this topic
#1 David1701
David1701
  • Members
  • PipPip
  • 28 posts
  • Name:David James
  • Car :‘06 Civic 2.2 iCDti
  • LocationMansfield
Posted 05 July 2018 - 10:44 PM
Hi,
I’ve a engine warning light come on my 2006 Civic 2.2 icdti, about ten seconds after starting engine, comes on after turning ignition on and not starting engine, got the RAC out, plugged his laptop in which showed a P2004 fault, so he cleared it and others which were left in the memory, seemed sorted, but came back after driving about, looking it up it seems it’s a common fault, rectified by a improved part, the imrc frquency solenoid valve, has anyone had the same on a 06 Civic 2.2 icdti ? If so do you have a part number for Honda please ?
#2 F6HAD
F6HAD
    Affiliate / Co-Founder
  • Administrators
  • 12,862 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 05 July 2018 - 10:55 PM
Your intake manifold is likely badly coked up due to egr soot build up and the manifold flap is sticking. It's very common.
Do you ever notice a hesitation around 2k RPM?
I would recommend removing your intake, cleaning out throughly and then blanking the egr and remap.
Changing the imrc valve is just treating the symptom but not addressing the underlying cause.
Drop me a line if you want pricing for the egr blanking and remap.
  • David1701 likes this
Posted Image
#3 Grayedout
Grayedout
    Advanced Member
  • Members
  • PipPipPip
  • 385 posts
  • Name:Graham Marshall
  • Car :2004 Accord 2.2
  • LocationDerbyshire
Posted 06 July 2018 - 08:53 AM
Can highly recommend the EGR blanking and remap by Fahad as it solved the problems I was having on my 2004 iCDTi  :)
#4 accord_n22
accord_n22
    Advanced Member
  • Members
  • PipPipPip
  • 697 posts
  • Name:Alex
  • Car :Honda Accord I-CTDI
  • LocationHertfordshire
Posted 06 July 2018 - 08:44 PM
Genuine Honda part for the IMRC is here if you need it - its not cheap
Honda part number: 36190RSRE01
https://www.coxmotor...alve-2006-2011/
Edited by accord_n22, 06 July 2018 - 08:44 PM.
#5 David1701
David1701
  • Members
  • PipPip
  • 28 posts
  • Name:David James
  • LocationMansfield
Posted 07 July 2018 - 05:56 AM
Thanks Guys, warning light has now gone off and stayed off, IMRC butterfly valve is free, I've tried it, got a OBD2 scanner on order to be able to reset it, car has only done 80K, so would this have generated enough soot to cause problems ?
#6 antdad
antdad
    Advanced Member
  • Members
  • PipPipPip
  • 131 posts
  • Name:Tony
  • Car :Tourer i-cdti 07
  • LocationHeathrow
Posted 07 July 2018 - 07:35 AM
It make help, try whizzing in some egr cleaner.
#7 F6HAD
F6HAD
  • Administrators
  • 12,862 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 07 July 2018 - 01:02 PM
It's normally the lower mileage cars that have the issue. Still worth cleaning out the intake, all it will cost is time and effort but the car feel a lot nicer.
Posted Image
#8 accord_n22
accord_n22
    Advanced Member
  • Members
  • PipPipPip
  • 697 posts
  • Name:Alex
Posted 07 July 2018 - 02:00 PM
Cleaning the inlet manifold is definitely something that will help - there is a guide on here somewhere.
Its quiet involved though.
I am on 185k miles and have always wanted to clean the inlet but its something that I dont think I can do.
I have cleaned the EGR valve every two years though including the swirl flap assembly. Both are quite easily to remove.
Clean the MAP and MAF sensors and give the car a good service , new oil, air filter and oil filter and the car will run great.
Makes a massive difference and amaze by the build up of sot and carbon around the  EGR inlet to the manifold.
I clean this regularly and have not had any issues from the ownership of the car.
See the build up of from around 50k miles.
#9 David1701
David1701
  • Members
  • PipPip
  • 28 posts
  • Name:David James
  • LocationMansfield
Posted 10 July 2018 - 12:36 AM
How do you do that ? Take out the air filter and spray it down the tube with the engine running ? Is it effective?
#10 David1701
David1701
  • Members
  • PipPip
  • 28 posts
  • Name:David James
  • LocationMansfield
Posted 10 July 2018 - 12:37 AM
That looks a lot of soot for only 50k ?
#11 David1701
David1701
  • Members
  • PipPip
  • 28 posts
  • Name:David James
  • LocationMansfield
Posted 11 July 2018 - 03:27 PM
Thanks, Cox says £126, my local Honda Dealer says £143 for the same part ! Ouch !
#12 David1701
David1701
  • Members
  • PipPip
  • 28 posts
  • Name:David James
  • LocationMansfield
Posted 11 July 2018 - 03:30 PM
http://typeaccord.co...ning-on-i-ctdi/
This looks like the one you mentioned Alex ?
