Water pump change
Wilderman
Hampshire
Gen7 Vtec sport
Driving home from Bristol last night and the air con stopped working then about half hour later engine light came on and temp gauge at max. Found most of the coolant gone and from what I can tell its coming from water pump area. So I'm pre-empting the worst and asking if changing water pump is a diy job? Thanks.
Can be if you have tools, I would say you might as well do chains, tensioner and guides as well as water pump.
Sent from my LG-K100 using Tapatalk
