Jump to content
Intermittent Knock from front end
  • Please log in to reply
6 replies to this topic
#1 jamesoc91
jamesoc91
    Newbie
  • Members
  • Pip
  • 5 posts
  • Name:James
  • Car :2.2 i-dtec EX
  • LocationIreland
Posted 23 July 2018 - 05:45 PM
Hi All,
I am trying to diagnose a problem with my 2.2 idtec.
I  listening to a knock coming from the front end.
It happens when I come to a full stop and then again when I start moving again, however it only happens when the car has got hot, I noticed it with our recent spell of good weather. This same knock came last year when I was abroad with the car, but it went away when I got home so i didn't investigate it any further.
I had one mechanic look at it a few weeks ago and he claimed it was an engine mount that he claimed to tighten... i assume just to get rid of me and keep me quiet. He also told me that there was a small noise from the differential.
I then replaced the anti roll bar drop links and bushes as the bushes looked worn. This seemed to make the knock a bit quieter but now is back to what it was at again.
Today I phoned a mechanic and I described the symptoms on the phone and I was told it is more than likely the DMF.... :(
However I don't think it is. I still get the clunk when the car has been knocked out of gear and roll up to the stop. The clutch is not giving any issues, that are noticeable to me anyhow.
The knock doesn't happen when going over speed bumps and when the car has been on a long run it knocks at low speeds and sounds like a ball joint to me, but surely the mechanic should have picked up on a ball joint when he was checking it out for me..
Has anybody else had this issue and would be able to shed some light for me? Or else am I forgetting something
Thanks,
James
#2 Mr Honda
Mr Honda
    Advanced Member
  • Members
  • PipPipPip
  • 1,284 posts
  • Name:Honda
  • Car :Accord
  • LocationEire
Posted 24 July 2018 - 01:43 PM
What mileage is on the car, could be engine mount, could be wishbone bushes, and as Mel's thread seems to suggest the possibility of steering rack issue, you need to get a trusted mechanic to get it on a lift and spend bit of looking things over.
#3 JLPK
JLPK
  • Members
  • PipPip
  • 62 posts
  • Name:phil
  • Car :Honda Accord
  • Locationselby
Posted 03 August 2018 - 08:14 PM
Mine does it. Only in warm weather. A quiet clonk when pulling away or stopping. Does it when stopping in neutral so nothing to do with clutch or drivetrain. The article about US accords below is interesting:
http://hondanews.net...is-it-safe.html
I don't know if the uk accords have the same ball joints as the US ones.
#4 jamesoc91
jamesoc91
    Newbie
  • Members
  • Pip
  • 5 posts
  • Name:James
  • LocationIreland
Posted 23 August 2018 - 01:59 PM
Ok so development from this.
I dropped the car into the garage and they found a worn inner tie rod. This got replaced but didnt solve the issue. Then 2 weeks later I started having some clutch slip . So now the DMF and clutch have been replaced . But the knock is still there. Garage still cant find it. I can get it to knock when the car is hot and switched off when I rock the steering wheel.
So now I'm down to thinking it's either the rack or CV joint. Not feeling and wander in the steering but when I turn the steering slowly with the car running I can feel the steering almost moving in steps.
Any ideas before this turns into a bottomless pit of money
#5 Stevearcade
Stevearcade
    TA Friend
  • Super Moderators
  • 6,862 posts
  • Name:Steve
  • Car :2003 Accord CM2
  • LocationEastbourne
Posted 23 August 2018 - 02:17 PM
If it's the CV joints, I'd have thought you'd be experiencing wobble in the steering wheel.
My CM2 - Cold Air Intake with K&N Filter, Custom 2.5" Stainless Steel Exhaust, Reflashed ECU, Custom Made 8J Steelies from Extreme Offset, BC Racing Coilovers, Short Shifter, Type-R Gear Knob, XCarLink iPod Interface, Interior & Exterior LED Bulb Conversion, Wind Deflectors, Yellow Fog Lamps, JDM size plates, Type S Grill (with blacked out chrome), Front & Rear Type S Skirts.
#6 Mr Honda
Mr Honda
    Advanced Member
  • Members
  • PipPipPip
  • 1,284 posts
  • Name:Honda
  • Car :Accord
  • LocationEire
Posted 24 August 2018 - 09:12 AM
Have a look at your calipers and make sure they're not binding, the knock you get when you stop and move on again could be caliper related. Same with the notchy steering you're probably feeling the caliper binding a bit more,
#7 Bounder
Bounder
    Advanced Member
  • Members
  • PipPipPip
  • 386 posts
  • Name:Huan
  • Car :Accord Type S CW3
  • LocationCo Cork Ireland
Posted 24 August 2018 - 10:01 AM
You need to get under the car on a set of ramps, and use a mechanics stethoscope to listen while someone turns the wheel back and forth, you should be able to pinpoint the source of the noise after a while.
Even holding onto the tie rods at the joint will give you an indication of the problem if its that part, it could also be the balljoints as already mentioned.
