Jump to content
Braking issues after pad change.
  • Please log in to reply
4 replies to this topic
#1 antdad
antdad
    Advanced Member
  • Members
  • PipPipPip
  • 110 posts
  • Name:Tony
  • Car :Tourer i-cdti 07
  • LocationHeathrow
Posted 26 July 2018 - 07:55 AM
Just thought I'd change the front pads as I'm going over the car bit by bit and they were looking worn, easy enough except the peddle just won't harden up as it self adjusts.  I think it could only be air in the system but the levels never changed and  no leaks to see...pedal firms up a bit but then sinks almost to the floor. How could that happen, any ideas?
#2 Mr Honda
Mr Honda
    Advanced Member
  • Members
  • PipPipPip
  • 1,280 posts
  • Name:Honda
  • Car :Accord
  • LocationEire
Posted 26 July 2018 - 01:29 PM
Did you put the lid back on the fluid reservoir when you were done? you may need to bleed the brakes properly if the pedals just going to the floor. there's no need to touch the bleed valves when just doing pad changes.
#3 antdad
antdad
    Advanced Member
  • Members
  • PipPipPip
  • 110 posts
  • Name:Tony
  • LocationHeathrow
Posted 27 July 2018 - 07:51 AM
That's the confusing part, I didn't touch the bleed valves or the fluid reservoir but the peddle isn't firming up after the pad change.
#4 Mr Honda
Mr Honda
    Advanced Member
  • Members
  • PipPipPip
  • 1,280 posts
  • Name:Honda
  • Car :Accord
  • LocationEire
Posted 27 July 2018 - 08:38 AM
After pushing the pistons in the caliper back, the fluid level would've risen in the reservoir, what's the level like now? After checking the level, start the car and just pump the pedal a few times, it should stiffen up. If it hits the floor again, you may need to bleed them as air must have gotten in somehow.
Edited by Mr Honda, 27 July 2018 - 08:42 AM.
  • antdad likes this
#5 antdad
antdad
    Advanced Member
  • Members
  • PipPipPip
  • 110 posts
  • Name:Tony
  • LocationHeathrow
Posted 31 July 2018 - 11:28 AM
Level appears to be normal and I agree somehow air must've got in, just waiting for vacuum pump to turn up so I can bleed them solo. Old bleed kit didn't fit the honda reservoir ffs!!
