Jump to content
High speed judder/vibration
  • Please log in to reply
13 replies to this topic
#1 stellamon
stellamon
  • Members
  • PipPip
  • 15 posts
  • Name:Nick
  • Car :Accord 2.2i-DTEC
  • LocationShrewsbury
Posted 24 August 2018 - 01:08 AM
Hi All,
I'm new to the site so hoping somebody can help.
I bought an Accord 2.2 i-dtec ES GT  2010 plate with 150000 on the clock.
Just been to Portugal and back, 3500 miles total, all good apart from a judder/vibration at the front end when going over 65mph.
If Anybody has any ideas I'd appreciate it?
Cheers Nick
#2 Mr Honda
Mr Honda
    Advanced Member
  • Members
  • PipPipPip
  • 1,279 posts
  • Name:Honda
  • Car :Accord
  • LocationEire
Posted 24 August 2018 - 09:15 AM
Get a wheel balance and alignment done, if it persists afterwards, it could be driveshaft related.
#3 Matt
Matt
    Advanced Member
  • Members
  • PipPipPip
  • 825 posts
  • Name:MattW
  • Car :CW3 Facelift ES GT
  • LocationYorkshire
Posted 24 August 2018 - 10:13 AM
What he said.
I had a pronounced vibration at about 50mph that vanished at higher and lower speeds. Issue was uneven tyre wear caused by poor alignment.
I didn't spot it, but when the tyre guy pointed it out it was pretty obvious. After it was set up (and two new tyres :blink: ) problem solved.
I'd get this checked before diving in at the expensive end...
#4 stellamon
stellamon
  • Members
  • PipPip
  • 15 posts
  • Name:Nick
Posted 25 August 2018 - 08:12 AM
Thank you both very much for the feedback, I will get it sorted and fingers crossed it will just be a wheel/tyre problem :)
#5 hale-pope
hale-pope
    Advanced Member
  • Members
  • PipPipPip
  • 139 posts
  • Name:Benedict OHalloran
  • Car :10 i-dtec tourer ex
  • LocationUnited Kingdom
Posted 07 September 2018 - 06:34 AM
How did you get on? I have a vibration at around 60 but m it goes away at higher speeds and I have had my tracking and balancing done and my tyres are all fine. I changed one propshaft bush as the steering was cranky at stop and start speeds and whilst the clanking stopped I still have the vibration. Any other ideas anyone?
#6 DazTheMe
DazTheMe
  • Members
  • PipPip
  • 55 posts
  • Name:Darren
  • Car :Accord 2.2i Dtec
Posted 07 September 2018 - 02:51 PM
I'm guessing it's most commonly the inside CV joint on the nearside driveshaft. I have the exact same problem for quite a while.
It's on the list next do to but just had MOT, wheel bearing, service, 2 tyres.
Unsure weather to replace with a shaftec or J & R one. Anyone who's done this before what part did you use?
I'll be sure to post if it fixes the judder issue when it's done though.
  • honda_saj likes this
#7 DazTheMe
DazTheMe
  • Members
  • PipPip
  • 55 posts
  • Name:Darren
Posted 26 September 2018 - 06:31 PM
Instead of making a new drive shaft related thread, I thought I'd just bump this one. Looking at different driveshaft options...Does the 2.2 150bhp share the same part as the 180bhp type S? As I've only found a few listed for a CU3 150bhp but seperate ones listed for the CU3 180bhp type S.
Would the type S one fit the other 8th gen diesels? https://www.euspares...nparts/13478072
*Edit - Lings parts numbers for the type S and the ES-GT are identical. So I'm hoping that'd indicate they share driveshafts unless someone whos done this job before knows otherwise.
Edited by DazTheMe, 26 September 2018 - 06:47 PM.
#8 F6HAD
F6HAD
    Affiliate / Co-Founder
  • Administrators
  • 12,758 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 26 September 2018 - 08:19 PM
I haven’t done this job but can’t see any reason why they would be different.
Posted Image
#9 julekasMobilek
julekasMobilek
  • Members
  • PipPip
  • 45 posts
  • Name:julius
  • Car :honda accord
  • LocationVilnius, Lithuania
Posted 28 September 2018 - 11:50 AM
I think they should be different because type is engine is more powerfull than stock 2,2 i-dtec. It should fit, because gearboxes type s and stock diesels are identical. So in conclusion type s driveshaft should be stronger and last longer :)
#10 F6HAD
F6HAD
  • Administrators
  • 12,758 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 28 September 2018 - 05:58 PM
As per above part numbers are identical. They’re not different.
Posted Image
#11 Ashzz
Ashzz
    Advanced Member
  • Members
  • PipPipPip
  • 155 posts
  • Name:Ashzz
  • Car :2.4 accord
  • LocationBlackburn
Posted 11 October 2018 - 09:02 AM
Hi guys, don't want to hijack the thread but rather than start a new thread wanted to ask do the 8th gen petrols suffer with driveshaft issues?
#12 DazTheMe
DazTheMe
  • Members
  • PipPip
  • 55 posts
  • Name:Darren
Posted 11 October 2018 - 05:06 PM
Maybe eventually, I would of thought it'd wear a lot slower though as the diesel puts alot more torque through the driveshaft than the petrol.
#13 hale-pope
hale-pope
    Advanced Member
  • Members
  • PipPipPip
  • 139 posts
Posted 18 October 2018 - 09:23 AM
I had vibrations but only at 55-65mph.  I changed engine mounts and dirvieshaft bushes.  An expensive thing to do but this solved the problem.  My idtec 2009 is on 187k so i cannot complain......but obviously do!
#14 DazTheMe
DazTheMe
  • Members
  • PipPip
  • 55 posts
  • Name:Darren
Posted 23 November 2018 - 12:23 PM
Have to ask before buying the wrong socket, is the axle nut 36mm?
