Jump to content
I-ctdi is using water
  • Please log in to reply
5 replies to this topic
#1 silverVTEC
silverVTEC
  • Members
  • PipPip
  • 98 posts
  • Name:rhys
  • Car :CG9
  • Locationwest midlands
Posted 04 October 2018 - 06:00 PM
I have a problem with my ctdi using water have had to top it up twice since my ownership I’ve had the car for about 2 months so about once a month it needs topping up, the car isn’t over heating and has not mixed the oil with the water and is running perfect them temperature needle sits where it is supposed too just confused as to why it’s using water any ideas people?
#2 F6HAD
F6HAD
    Affiliate / Co-Founder
  • Administrators
  • 12,770 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 04 October 2018 - 08:59 PM
It’s going to be leaking somewhere. Have a pressure test carried out.
Posted Image
#3 silverVTEC
silverVTEC
  • Members
  • PipPip
  • 98 posts
  • Name:rhys
  • Car :CG9
Posted 04 October 2018 - 10:22 PM
I’ve had a good look around the engine and carnt find any visible signs of a leak, I will get a pressure test and take it from there, thanks for the help
#4 Matt
Matt
    Advanced Member
  • Members
  • PipPipPip
  • 828 posts
  • Name:MattW
  • Car :CW3 Facelift ES GT
  • LocationYorkshire
Posted 05 October 2018 - 04:38 PM
After I changed the coolant in mine it took a few runs to work all the air out the system. After a couple of minor top-ups it settled, and didn't need additional fluid after that.
Out of interest how much are you having to add, and how full are you filling it?
One of my previous cars (not a Honda) would never sit on full. I've no idea where the water went. It never went to to low mark, but refused to maintain the full level. I stopped worrying about it eventually  :D
#5 Mr Honda
Mr Honda
    Advanced Member
  • Members
  • PipPipPip
  • 1,280 posts
  • Name:Honda
  • Car :Accord
  • LocationEire
Posted 08 October 2018 - 02:43 PM
If it's getting into the oil you would see excessive white smoke out of the exhaust. you could have a minor leak which is going nowhere or you could have an issue with wet floor carpets and your internal heater matrix is fecked. Don't top up with water, use coolant and check all rad hoses are relatively fresh looking and not perished.
As Matt says, after a coolant refresh you will need to top up again once all the air get circulated out of the system, this could take a couples of journeys/top-ups to be sure all the air pockets are gone.
#6 silverVTEC
silverVTEC
  • Members
  • PipPip
  • 98 posts
  • Name:rhys
  • Car :CG9
Posted 11 October 2018 - 10:38 AM
I keep on having to top it up with just over half a kettle of water every month, I’m currently using water as I don’t want to waste money on coolant if it’s just going to disappear, I have no wet carpets, no oil mixing and no smoke at all out of the exhaust. I think I have found the problem the top of the radiator is damp and I have a very small leak out of the top of the radiator where the small pipe goes from the radiator to the water tank, there is very minor bubbling around where the nipple comes out of the radiator, but I don’t know if this will cause this much water usage looks like I’m going to have to buy a new radiator and take it from there.
