Hole on car floor
accord2001
Dublin
Fr-v
Hi my honda just failed inspection due to a hole on driver’s floor, however to fix problem the test centre require welding and not fibreglass patching, the problem is that above the holes there’s wires running thru, in that case is it gonna be very expensive job since they have to disconnect wires etc
If your going to have it done by a garage they will probably have a way of protecting the wiring while they weld.
And if they do need to move it out the way I shouldn't think it will add a lot more time.
Best to get a few quotes and see how expensive it's going to be.
