Jump to content
Any plumbers on here
  • Please log in to reply
4 replies to this topic
#1 TypeR
TypeR
    Iron Man
  • Administrators
  • 5,880 posts
  • Name:Honda Guy
  • Car :Accord 05 Exec cdti
  • LocationWest Yorkshire
Posted 04 November 2018 - 10:24 AM
Hi
Wondering if we had any plumbers on here who could help advise me on an issue I’m having.
Seem to be suffering from what is known as ‘water hammering’ when closing taps upstairs in the house. Never had this before and recently started.
Any ideas on fix/investigation?
Honda Accord 2.2 I-CTDI Executive with Premier Tuning Stage 1 EGR OFF 18" Storms, LED number plate lights, LED sidelights, HID 4300K and X carlink with bluetooth handsfree. Diesel Power
#2 stellamon
stellamon
  • Members
  • PipPip
  • 15 posts
  • Name:Nick
  • Car :Accord 2.2i-DTEC
  • LocationShrewsbury
Posted 04 November 2018 - 11:12 AM
I had this recently and discovered it was due to the in house stop tap under the sink not being fully open, effectively lowering the water pressure.
Could anything recent have caused a drop in your water pressure?
Try closing the stop tap, emptying the system then fully re-opening it.
Edited by stellamon, 04 November 2018 - 11:12 AM.
#3 TypeR
TypeR
    Iron Man
  • Administrators
  • 5,880 posts
  • Name:Honda Guy
Posted 04 November 2018 - 05:33 PM
Will try that, thanks for the advice
#4 antdad
antdad
  • Members
  • PipPip
  • 98 posts
  • Name:Tony
  • Car :Tourer i-cdti 07
  • LocationHeathrow
Posted 05 November 2018 - 03:25 AM
Water hammer is a shock wave sent through the pipes by taps or valves opening or shutting quickly but varying mains water pressure can cause it too. You can fit a device called shock arrestor close to the source as well as a pressure reducing valve (PRV) after the mains stop **** to stabilise pressure. Sometimes it's caused by worn ball valves or faucet washers or even mineral build up on gate valves but if you're sure it's the upstairs taps make sure the surrounding pipe work is well secured first if at all possible, certainly worth draining down your system and seeing if that helps.
https://www.screwfix...r-0-16ltr/8199v
Edited by antdad, 05 November 2018 - 03:38 AM.
#5 Pete1958
Pete1958
    Advanced Member
  • Members
  • PipPipPip
  • 488 posts
  • Name:Peter Aldred.
  • Car :2004 2.4 EX 7th Gen.
  • LocationMiddlesex.
Posted 05 November 2018 - 07:45 AM
Can also be caused by pipes not being secured properly, especially long lengths in the loft area.
