Jump to content
5 lug convertion
  • Please log in to reply
2 replies to this topic
#1 RoyalHD
RoyalHD
    Newbie
  • Members
  • Pip
  • 6 posts
  • Name:Kenneth Braathen Mauer
  • Car :CG9
  • LocationJessheim
Posted 28 April 2019 - 08:53 AM
Thinking about doing a 4 to 5 lug convertion on my CG9 (2.0 Euro/JDM). I've searched around alot but haven't really found a exact parts list, but I've found out that the v6 parts should fit as they share the same knuckle. My main concern is if the front calipers will fit. The rear calipers seems to be the same, so I haven't included it in my list. So please correct my list or confirm that everything is correct before i buy everything.
Front:
Wheel bearing - 2.0 or v6 (same size)
Hubs - v6
Rotors - v6
Pads - v6
Dual piston calipers - v6
Rear:
Wheel hubs - v6
Rotors - v6
Pads - v6
If the brake lines is different I'll make them myself.
#2 dzizajdm
dzizajdm
    Newbie
  • Members
  • Pip
  • 9 posts
  • Name:dziza
  • Car :''00 Accord ES
  • LocationLithuania
Posted 03 May 2019 - 06:25 AM
If the end goal is simply to have a 5lug - the simplest way to do it is to source a full hubs off a 2.3 1998-2002 Accord. So it will be a direct swap with your current calipers and the only thing you will have to buy is a new set of brake discs.
#3 RoyalHD
RoyalHD
    Newbie
  • Members
  • Pip
  • 6 posts
  • Car :CG9
  • LocationJessheim
Posted 06 June 2019 - 09:53 AM
Didn't get a notification on your reply for some reason 🤷🏻‍♂️
As far as i know the 2.3 has 4 lugs, but I guess you ment the v6.
Since i have to take the whole knuckle assembly out anyway i might as well change out everything. That's why i want to buy the parts new. But one option is to get a hold of the front knuckles, change out everything and sell the old ones 🤷🏻‍♂️
