Radiator replacement compatibility
antdad
Heathrow
Tourer i-cdti 07
Had a bit of a mare the other day, basically I managed to damage the lower valance as well as the rad and fans as the jack slipped off the front subframe. My stupid fault for being in a rush but that's just the half of it, anyhow damaged rad is already radsealed so I was going to get a replacement from a scrappy.
Will any rad from any year i-cdti saloon or tourer do for a N22A engine?
Not sure if they're interchangeable between facelift and non-fl. Honda improved the cooling in the FL, therefore it didn't need a deeper bumper grille. I'm not certain if a facelift rad will do a pre-fl...
