Jump to content
Water in Tyre Well
  • Please log in to reply
12 replies to this topic
#1 J_VTEC
J_VTEC
    Advanced Member
  • Members
  • PipPipPip
  • 210 posts
  • Name:Jay
  • Car :Accord Type S
  • LocationNorth East
Posted 11 August 2019 - 03:23 PM
Hi All,
Yesterday a discovered a large amount of water in the tyre well of my Accord. I emptied it out and dried it. Today I've checked it again and I can see a couple of runs of water running from the O/S rear corner of the boot to the tyre well. I've tried researching the issue online and came up with everything from leaky boot seal to leaking sells around the tail lights.
Is this a common fault? If so, is there a sure fire way of diagnosing and fixing it?
Cheers.
Posted Image
#2 Reiver
Reiver
    Advanced Member
  • Members
  • PipPipPip
  • 110 posts
  • Name:Alan
  • Car :'04 i-CTDi Tourer
  • LocationEdinburgh
Posted 11 August 2019 - 05:37 PM
I had the leaking seam behind the tail lights. Diagnosis was to run water hose at full flow starting from bottom (spraying at various angles to ensure penetration at each step) to top and then along roof watching (or feeling) for when water starts entering side wells. Not sure if your car is a tourer but they mostly seem to be roof bar seal leaks. Sometimes just removing and refitting roof bars resolves it.
#3 J_VTEC
J_VTEC
    Advanced Member
  • Members
  • PipPipPip
  • 210 posts
  • Name:Jay
Posted 11 August 2019 - 05:52 PM
Thanks! Mine's a saloon. I should've stated that. I had a similar issue with my Civic (FN2 Type S GT) when I started to get mould in the boot. The rear seatbelt on the driver's side was soaking wet too. Turned out it was the seals on the rear hatch electric harness conduits that were full of crud around the grommets. Pulled them out, cleaned the crud off and the surrounding area and popped out all back together. No leaks (or mould) since. In the case of the accord, I might have to check the seals around the O/S light cluster.
What do you think?
Posted Image
#4 Matt
Matt
    Advanced Member
  • Members
  • PipPipPip
  • 886 posts
  • Name:MattW
  • Car :CW3 Facelift ES GT
  • LocationYorkshire
Posted 12 August 2019 - 04:38 PM
Do I remember something about blocked sunroof (if you've got one) drainage channels sometimes causing this?
#5 J_VTEC
J_VTEC
    Advanced Member
  • Members
  • PipPipPip
  • 210 posts
  • Name:Jay
Posted 12 August 2019 - 05:51 PM
No sunroof so it can't be that. Just checked the boot again and sure enough it's full of water again which it worrying considering it was cleaned out and dried on Saturday.
Worst part is, I can't see any evidence of where it's coming from. Had a quick look at the rear light cluster and it all looks dry.
There also appears to be grit in it too.
Posted Image
#6 JapCar
JapCar
    Advanced Member
  • Members
  • PipPipPip
  • 128 posts
  • Name:Japy
  • Car :Accord i-VTEC 2.0 EX
  • LocationBristol UK
Posted 12 August 2019 - 06:07 PM
You can put dry paper or similar on/in suspicious places to find out where water is coming from...
#7 J_VTEC
J_VTEC
    Advanced Member
  • Members
  • PipPipPip
  • 210 posts
  • Name:Jay
Posted 12 August 2019 - 07:10 PM
I'll give it a go as soon as it stops raining. I've heard talc can be used too.
Posted Image
#8 Pete1958
Pete1958
    Advanced Member
  • Members
  • PipPipPip
  • 491 posts
  • Name:Peter Aldred.
  • Car :2004 2.4 EX 7th Gen.
  • LocationMiddlesex.
Posted 13 August 2019 - 07:48 AM
Put a ring of talcum powder around the wheel well, it should show up the flow direction :) .
  • Richard B likes this
#9 J_VTEC
J_VTEC
    Advanced Member
  • Members
  • PipPipPip
  • 210 posts
  • Name:Jay
Posted 13 August 2019 - 11:16 AM
Thanks, sounds like a good idea. It'll have to wait until the weekend now though.
Posted Image
#10 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 992 posts
  • Name:Stephen
  • Car :Accord 7 Estate 2005
  • LocationKT8 Postcode
Posted 15 August 2019 - 07:58 PM
Weekend looks like good weather for ducks.
Try parking the car on the other camber of the road for a night or two, which will eliminate one side from the equation.
Edited by Channel Hopper, 15 August 2019 - 07:58 PM.
#11 J_VTEC
J_VTEC
    Advanced Member
  • Members
  • PipPipPip
  • 210 posts
  • Name:Jay
Posted 15 August 2019 - 09:04 PM
OK,a quick update.
So the other day, I reseated the boot seal down the sides and among the bottom of the boot opening. I had noticed the lower plastic trim panel was a bit loose so secured that whilst I was at it. The lip of the seal was under the trim panel.
When I checked the Civic which has a similar arrangement,I noticed the lip of the seal was OVER the trim panel. I did the same with the Accord and used the car as normal. We had rain the following day and up until now, no leaks.
I'm going to keep my eye on it but so far, so good.
Maybe an ill-fitting boot seal was the issue? Only time will tell.
Thanks for the advice so far 👍
Posted Image
#12 JapCar
JapCar
    Advanced Member
  • Members
  • PipPipPip
  • 128 posts
  • Name:Japy
Posted 15 August 2019 - 09:51 PM
It was good to give some pictures to illustrate explanation...
#13 J_VTEC
J_VTEC
    Advanced Member
  • Members
  • PipPipPip
  • 210 posts
  • Name:Jay
Posted 20 August 2019 - 07:41 AM
Fair point. I'll post some when I get the chance. 😉
Posted Image
