Jump to content
total power loss 2.2 idtec
  • Please log in to reply
5 replies to this topic
#1 Whiteakita
Whiteakita
  • Members
  • PipPip
  • 31 posts
  • Name:Michael
  • Car :2009 accord idtec
  • LocationBishop auckland
Posted 30 October 2019 - 02:11 PM
hi all, my car has just lost nearly all power where it will barely pull away and top speed of 25mph.
i have checked fault code which is p0402 egr high flow.
does anyone know what this means and how to fix it ?
im guessing the egr valve is blocked and needs cleaning, ive looked down the back of the engine and it looks a real pig to get at.
there also seem to be 2 egr valves 1 on the left and on the right of the engine.
i have had limp mode in cars before but nothing that has taken away as much power as this, it would not drive up a incline.
any help would be great.
#2 Cliffordski
Cliffordski
    And still...
  • TA Friends
  • PipPipPip
  • 1,467 posts
  • Name:Cliff
  • Car :13 Tourer 2.4 EX man
  • LocationCounty Durham
Posted 30 October 2019 - 07:47 PM
The EGR pipes are known to split on these.
#3 csak1981
csak1981
  • Members
  • PipPip
  • 16 posts
  • Name:Christian
  • Car :Accord Tourer
  • LocationScotland
Posted 30 October 2019 - 08:47 PM
Yep diesel fumes coming into cabin is a symptom. You'll notice it when idling at traffic lights then with airflow produced from car moving it will go away
#4 stellamon
stellamon
  • Members
  • PipPip
  • 87 posts
  • Name:Nick
  • Car :Accord 2.2i-DTEC
  • LocationShrewsbury
Posted 30 October 2019 - 10:34 PM
Mine was leaking when I bought it a while back but the car still drove okay, just fumes all over the place. This must be something else, or a combination of faults, not too helpful I know.
Does the turbo whistle when you accelerate?
Edited by stellamon, 30 October 2019 - 10:40 PM.
#5 csak1981
csak1981
  • Members
  • PipPip
  • 16 posts
  • Name:Christian
  • LocationScotland
Posted 31 October 2019 - 12:12 PM
Yep mine was also leaking when i got it. If yours is a bigger spilt then its probably to much so it's thrown a code. I would think if the split is bigger then you should be able to smell the fumes as mine was quite bad with a small split and no code
#6 F6HAD
F6HAD
    Affiliate / Co-Founder
  • Administrators
  • 12,934 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 31 October 2019 - 04:19 PM
Not seen this before on an idtec. I believe it means your egr is stuck open and not closing properly. Has the ecu been messed with? Dpf or egr removed? Drop me a line if you want to book for a diagnostic session
Posted Image
