Third brake light saloon
Thank you.
Now, the problem is that I can't get the flipping bulb out. Tried turning the plastic housing counter-clockwise and it doesn't budge.
Hmmm, It may be that the bulb has slightly melted and cause the socket to fuse into the fitting.
or might need alittle more force?
I fitted an OEM spoiler to my accord with built in LED brake light... so I disconnect the one on the rear shelf and used that to power the spoiler one instead. :)
It was a bugger to get out, hadn't melted or anything it's just in there really tightly.
Hi Everyone, I've just fitted an OEM boot lid with a spoiler to my 7th Gen accord. Does anyone know if the parcel shelf brake light and the spoiler light work together? Or is it one or the other?
Is there a separate harness needed to get both working?
