Jump to content
Power steering leak
  • Please log in to reply
5 replies to this topic
#1 block
block
    Advanced Member
  • Members
  • PipPipPip
  • 178 posts
  • Name:Paul Smith
  • Car :56 Ex diesel saloon
  • LocationWorksop
Posted 10 January 2020 - 03:19 PM
Good afternoon,
Can anyone help me please? Checked my levels the other day and topped up the power steering fluid. Just been under the car to change the oil and there is fluid everywhere, and the power steering reservoir is below minimum level, that and the yellowy colour of the fluid tells me its a leak with the power steering. Checking the reservoir and pump at the top of the engine i could see no visible leaks, so its at the bottom somewhere. One of the hoses seems to run in front of the radiator right at the bottom, and this is covered in fluid, I think this is a power steering hose, is this correct? It all seems to be in one piece, but as i have no one around at the minute to operate the power steering while im under the car i cant locate where the leak is, but it appears to be the one described above. Can anyone with experience of this give any advice please?
#2 F6HAD
F6HAD
    Affiliate / Co-Founder
  • Administrators
  • 12,961 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 12 January 2020 - 10:05 AM
I can’t recall if it’s the one you mention, but there is a known issue with leaking power steering hose on the 7th gen diesel Accord. Do a search on the forum to try and dig out the old posts that reference it.
Posted Image
#3 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 1,007 posts
  • Name:Stephen
  • Car :Accord 7 Estate 2005
  • LocationKT8 Postcode
Posted 12 January 2020 - 06:20 PM
https://www.ebay.co....-cAAOSw1kRbC7v8
From this thread
http://typeaccord.co...wer#entry254259
My tourer leaks ever so slightly, I topped up the reservoir a year ago and it will need a couple of teaspoons worth next time I open the bonnet.
#4 antdad
antdad
    Advanced Member
  • Members
  • PipPipPip
  • 185 posts
  • Name:Tony
  • Car :Tourer i-cdti 07
  • LocationHeathrow
Posted 12 January 2020 - 06:26 PM
Two threads open.
#5 saj
saj
    Advanced Member
  • TA Friends
  • PipPipPip
  • 996 posts
  • Name:m
  • Car :8th Gen IDTEC Saloon
  • LocationEnfield
Posted 12 January 2020 - 06:48 PM
I think amazon may have the hose available for 20 quid.
#6 block
block
    Advanced Member
  • Members
  • PipPipPip
  • 178 posts
  • Name:Paul Smith
  • LocationWorksop
Posted 13 January 2020 - 12:31 PM
Thanks all.
Its the lower hose i need, the one that runs in front of the radiator.
If a mod can close this please as i also posted it on the generic fault page.
Thank you.
