Hi,
I have done a search but all the info seems be based on prefacelift models - and getting the dealer to install clips etc. Mine is a 2007 which apparantly should have this problem fixed.
My passenger side headlight seems to mist up quite bad - putting on the lights doesn't clear it either.
Are there any vent tubes or holes in the headlight that I can check to see if they are not blocked?
Failing that - how easy it to take the headlight out to re-seal them?
Thanks.
Thanks.
