Hi folks
I have been getting an issue of late where I get the ABS, !, and VSA warning lights on my dash. These have come and gone without any change in the way the car goes.
However two days ago I started getting an intermittent engine management light and the revs die to tick over. I have been able to get it restarted and drive fine with the engine management light on but if the ABS and ! come on whilst driving it cuts out again.
Took the car to my regular mechanic who done a diagnostic and came up with throttle position sensor fault and rear driver's side wheel speed sensor (ABS) fault. He referred me to Honda with this as he's not to familiar with diesels in general.
Have got a diagnostic check booked with Honda tomorrow but on rough estimates it will cost over £500 to repair if both sensors need replaced.
I just want to ask if this is a common issue and if a fault in one sensor could be causing the light to come on for the other? Is there anything else worth checking like dirt on the sensor, etc?
I'm rather new to diesels but have owned a few Hondas and have never had any engine trouble.
Many thanks in advance
